2004 Ford Explorer Sport Trac, Stellar Remote Start
millrhet8428
Member - Posts: 8
Posted: January 15, 2022 at 4:00 PM / IP Logged Link to Post Post Reply Quote millrhet8428
Awesome it works! Thank you! Do you have what should be hooked up for acc and ign. My blower motor is not coming on?
John
catback
Silver - Posts: 703
Posted: January 15, 2022 at 4:29 PM / IP Logged Link to Post Post Reply Quote catback
Do you have the Brown ignition wire connected as an Accessory on the STERS1050?
Vehicle Wiring Information
millrhet8428
Member - Posts: 8
Posted: January 15, 2022 at 4:36 PM / IP Logged Link to Post Post Reply Quote millrhet8428
I have it on the gray/yellow. Switched it to brown and it comes on. Do you know if grey/yellow needs to be hooked up also?
John
catback
Silver - Posts: 703
Posted: January 15, 2022 at 6:17 PM / IP Logged Link to Post Post Reply Quote catback
Gray/Yellow is powered when the key is in the ACC (Accessory) position*. It is not required for remote start.
* - ACC is not the only powered position, Gray/Yellow also receives power when the ignition switch is in the RUN position.
millrhet8428
Member - Posts: 8
Posted: January 15, 2022 at 9:03 PM / IP Logged Link to Post Post Reply Quote millrhet8428
Awesome, thank you again for the help. Everything is working correctly as it should.
John
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
