2019 Nissan Sentra PTS, Remote Start
perezjorgejr
Member - Posts: 6
Posted: January 30, 2022 at 3:39 PM / IP Logged Link to Post Post Reply Quote perezjorgejr
Has anyone ran into an issue when installing a remote starter where when you attempt to remote start the car the display says no key found? I installed an Prestige 57TM with an FLCART. The programming sequence when through fine, but the car won't start. I had a similar issue with an 2012 Nissan Altima. I double and triple checked my wiring. The only thing that i noticed was that the instructions ask to use "keyfob1", but I don't know how to tell if the fob im using is keyfob1 and it's the customers only fob.
Thanks !
Jp
djdeito
Copper - Posts: 100
Posted: January 30, 2022 at 10:13 PM / IP Logged Link to Post Post Reply Quote djdeito
What does the FLCART LED status show when you attempt to remote start the car?
2019 Nissan Sentra PTS, Remote Start - Last Post -- posted image.
silvercivicsir
Copper - Posts: 409
Posted: January 31, 2022 at 7:40 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
are you brake lights coming before it attempts to remote start ?
perezjorgejr
Member - Posts: 6
Posted: February 04, 2022 at 7:50 AM / IP Logged Link to Post Post Reply Quote perezjorgejr
He's bring the car back to me this weekend. I'll check for the status lights.. thanks!!
Jp
perezjorgejr
Member - Posts: 6
Posted: February 04, 2022 at 7:52 AM / IP Logged Link to Post Post Reply Quote perezjorgejr
I'm not too sure on the brake light - I'll check it this weekend. Someone else told me that if the Nissan Fob battery is low it can cause issues while programming
Jp
perezjorgejr
Member - Posts: 6
Posted: February 09, 2022 at 7:48 PM / IP Logged Link to Post Post Reply Quote perezjorgejr
So I found that their are two brake switches and I was wired to the wrong one. The customer is bringing his car in Saturday - hopefully switching to the "top" brake switch fixes the issue.
Jp
Thursday, May 30, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
