The 12 Volt’s Port Calculator
lineman26
Posted: May 26, 2022 at 2:07 AM / IP Logged Link to Post Post Reply Quote lineman26
Question, when using this websites round or slot port calculator that determines the port length after inputting the port surface area, the box volume and frequency you want the box tuned to. Am I correct in assuming that the correct box volume that is used is the gross volume minus only the speaker displacement as the port displacement will depend on the results of the calculator??? Or are you supposed to estimate the length in order to calculate the port volume, then put the true net box volume in the calculator?
Also, I found this site when searching for a sub box calculator that takes the sub TS details then displays the specific sub and box designs output frequency slope graph, allowing you to see how any type and size of box will sound with any sub. Anyone know of something like that
Car Audio shop manager - installer 1996 - 2005,
Saturday, February 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
