2018 Hyundai Tucson, Remote Start Alarm Wiring
rockinchaos3
Posted: January 23, 2023 at 11:47 PM / IP Logged Link to Post Post Reply Quote rockinchaos3
Hi, I have a 2018 Hyundai Tucson and it seems the wiring guide for the 2017 Hyundai Tucson is different than the 2018 model year as the wiring colors are definitely different than what is found.
I am looking for the proper wiring colors for a remote start system/alarm. So I need the lock/unlock, horn, parking lights, dome light, ignition wires, etc.
I am unsure if the ignition wires are different between keyed vs push to start but my car specifically uses push-to-start.
If it helps I am installing a Compustar remote start system so I need the wires for remote start functionality (the ignition) and the alarm basics.
If anyone could provide the proper wire colors similar to the 2017 Hyundai Tucson guide that would be fantastic.
tonanzith
Gold - Posts: 593
Posted: February 02, 2023 at 11:18 PM / IP Logged Link to Post Post Reply Quote tonanzith
Item     Wire Color     Polarity     Wire Location
12 Volts     Red (60A)     +     SJB-Dash Fuse Box, black 6 pin plug (B), pin 2
Ground     (chassis ground)
Starter     Red/Black     +     Driver Kick, blue 48 pin plug (MC11), pin 44
Ignition     Blue     +     Driver Kick, blue 48 pin plug (MC11), pin 48
Accessory     Green     +     Driver Kick, blue 48 pin plug (MC11), pin 30
Second Accessory     White     +     Driver Kick, blue 48 pin plug (MC11), pin 8
Ignition Interrupt     Green     Cut     SJB-Dash Fuse Box, rear, white 18 pin plug (F), pin 6
PTS 1     White     -     Start Stop Button Switch, white 16 pin plug, pin 1
PTS 2     Blue     -     Start Stop Button Switch, white 16 pin plug, pin 8
CAN Bus High     Green (C-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low     Orange (C-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus High 2     Green/Black (B-CAN)     Data     SJB-Dash Fuse Box, rear, white 18 pin plug (F), pin 3
CAN Bus Low 2     Blue/Black (B-CAN)     Data     SJB-Dash Fuse Box, rear, white 18 pin plug (F), pin 4
OBD 12 Volts     Blue/Black (7.5A)     +     OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground     Black     -     OBD-Data Link Connector, black 16 pin plug, pin 4
OBD Connector     Black          Under Driver Dash, Below Steering Column
IMMO Data     Blue (EMS COM)     Data     Driver Kick, blue 48 pin plug (MC11), pin 3
K Line     White     Data     OBD-Data Link Connector, black 16 pin plug, pin 12
Power Lock     Blue/Black     -     SJB-Dash Fuse Box, white 32 pin plug (D), pin 27
Power Unlock     Gray/Black     -     SJB-Dash Fuse Box, white 32 pin plug (D), pin 14
Lock Motor     Orange     Reverse     SJB-Dash Fuse Box, black 51 pin plug (C), pin 8
Driver Unlock Motor     Pink     Reverse     Driver Kick, white 68 pin plug (MF11), pin 64
Passenger Unlock Motor     Pink     Reverse     SJB-Dash Fuse Box, black 51 pin plug (C), pin 26
Factory Alarm Arm     Red (see Tech Doc 1300)     -     SJB-Dash Fuse Box, white 32 pin plug (D), pin 13
Factory Alarm Disarm     Pink (see Tech Doc 1300)     Double -     SJB-Dash Fuse Box, white 32 pin plug (D), pin 12
Lock Detection     Gray (see Tech Doc 1300)     Open     SJB-Dash Fuse Box, white 32 pin plug (D), pin 9
Unlock Detection     (same as lock detection)     -
Parking Lights     Blue/Orange (LF); Green (RF)     +     SJB-Dash Fuse Box, white 41 pin plug (A), pin 12 (LF); pin 29 (RF)
Parking Lights 2     Pink (LR); Yellow (RR)     +     SJB-Dash Fuse Box, black 51 pin plug (C), pin 50 (LR); pin 19 (RR)
Parking Lights -     Yellow     - 1680 Ohms     Headlight-Wiper Switch, black 16 pin plug, pin 14
Parking Lights MUX     Yellow     MUX     Headlight-Wiper Switch, black 16 pin plug, pin 14
Hazards     Yellow     -     SJB-Dash Fuse Box, rear, gray 51 pin plug (E), pin 30
Turn Signal (Left)     Yellow (LF); White (LR)     +     SJB-Dash Fuse Box, white 41 pin plug (A), pin 3 (LF); black 51 pin plug (C), pin 10 (LR)
Turn Signal (Right)     White/Black (RF); Pink (RR)     +     SJB-Dash Fuse Box, white 41 pin plug (A), pin 39 (RF); black 51 pin plug (C), pin 39 (RR)
Headlight     White     -     Headlight-Wiper Switch, black 16 pin plug, pin 15
AutoLights     Yellow     Cut     Headlight-Wiper Switch, black 16 pin plug, pin 14
Reverse Light     Red     +     SJB-Dash Fuse Box, black 51 pin plug (C), pin 11
Left Front Door Trigger     Blue     -     SJB-Dash Fuse Box, white 32 pin plug (D), pin 23
Right Front Door Trigger     Pink     -     SJB-Dash Fuse Box, white 32 pin plug (D), pin 8
Left Rear Door Trigger     Brown     -     SJB-Dash Fuse Box, white 32 pin plug (D), pin 22
Right Rear Door Trigger     Gray     -     SJB-Dash Fuse Box, white 32 pin plug (D), pin 21
Dome Light     Brown/Orange     -     Left Front Pillar, white 36 pin plug (MR11), pin 8
Trunk/Hatch Pin     White     -     SJB-Dash Fuse Box, white 32 pin plug (D), pin 25
Hood Pin     Orange/Black     -     SJB-Dash Fuse Box, white 41 pin plug (A), pin 38
Power Liftgate     Green/Black     -     Power Liftgate Switch, black 16 pin plug, pin 5
Power Liftgate 2     Green/Black (alternate location)     -     Driver Kick, white 68 pin plug (MF11), pin 51
Trunk/Hatch Release     Green (rear handle switch)     -     SJB-Dash Fuse Box, white 32 pin plug (D), pin 24
Trunk Release Motor     Blue     +     SJB-Dash Fuse Box, black 51 pin plug (C), pin 51
Tachometer     White     AC     Driver Kick, blue 48 pin plug (MC11), pin 47
Tachometer 2     Black/Orange (1.6L); Red (2.0L)     AC     Camshaft Position Sensor, engine driver side, black 3 pin plug, pin 2
Fuel Pump     White     +     Right of Dash Fuse Box, white 24 pin plug (CF11), pin 12
Rear Defroster     Green/Orange     - Latched     SJB-Dash Fuse Box, white 41 pin plug (A), pin 17
Mirror Defroster     (same as rear defroster)
Wiper Deicer     (same as rear defroster)
Left Front Heated Seat     Blue     +     A/C Control, white 24 pin plug, pin 2 or white 32 pin plug, pin 5
Right Front Heated Seat     Red     +     A/C Control, white 24 pin plug, pin 14 or white 32 pin plug, pin 17
Heated Steering Wheel     White/Orange     -     A/C Control, white 24 pin plug, pin 18 or white 32 pin plug, pin 27
Speed Sense     Brown     AC     Radio, white 24 pin plug, pin 16 or white 38 pin plug, pin 38
Brake Wire     Green/Black     +     Brake Switch, white 4 pin plug, pin 4
Brake Wire 2     Green/Black (alternate location)     +     SJB-Dash Fuse Box, white 41 pin plug (A), pin 37
Parking Brake     Gray/Orange     -     SJB-Dash Fuse Box, white 41 pin plug (A), pin 8
Horn Trigger     Gray/Orange     -     Horn Switch-Clock Spring, white 14 pin plug, pin 8
Horn Trigger 2     Gray/Orange (alternate location)     -     Driver Kick, blue 48 pin plug (MC11), pin 42
Horn - Factory Alarm     White     -     SJB-Dash Fuse Box, white 41 pin plug (A), pin 28
Wipers     Blue     +     Driver Kick, blue 48 pin plug (MC11), pin 21
Left Front Window (Up/Down)     White - Pink (auto down); (auto up-down, motor is part of module)     A     Power Window Main Switch, white 18 pin plug, pins 8 - 9
Right Front Window (Up/Down)     Gray - Green     A     Driver Kick, door harness
Left Rear Window (Up/Down)     Pink - Brown     A     Driver Kick, door harness
Right Rear Window (Up/Down)     Blue - Orange     A     Driver Kick, door harness
Sun Roof (Open/Close)     Brown and Green (open) (functions with ignition on only)     Both -     Sunroof Switch, white 6 pin plug, pins 5, 6
Sun Roof (Limit/Close)     Yellow and Green (close) (functions with ignition on only)     Both -     Sunroof Switch, white 6 pin plug, pins 3, 2
Radio 12V     Red     +     Radio, white 24 pin plug, pin 12 or white 35 pin plug, pin 10
Radio Ground     Black     -     Radio, white 24 pin plug, pin 24 or white 35 pin plug, pin 12
Radio Ignition     Blue/Orange     +     Radio, white 24 pin plug, pin 11 or 18 or white 35 pin plug, pin 22
Radio Illumination     Red/Orange (parking lights); Blue/Orange (dimmer)     +,-     Radio, white 18 pin plug, pins 8, 17 or white 35 pin plug, pins 6, 19
Factory Amp Turn-on     (M-CAN) (audio is SPDIF)
Power Antenna     Green     +     Radio, white 18 pin plug, pin 18 or white 35 pin plug, pin 5
Left Front Speaker (+/-)     White - Brown     +,-     Radio, white 18 pin plug, pins 2 - 11 or white 38 pin plug, pins 13 - 14
Right Front Speaker (+/-)     Black - Yellow or Red - Blue     +,-     Radio, white 18 pin plug, pins 3 - 12 or white 38 pin plug, pins 16 - 15
Left Rear Speaker (+/-)     Black - Yellow or Red - Blue     +,-     Radio, white 18 pin plug, pins 1 - 10 or white 38 pin plug, pins 1 - 2
Right Rear Speaker (+/-)     Green - Orange     +,-     Radio, white 18 pin plug, pins 4 - 13 or white 38 pin plug, pins 28 - 27
Left Front Speaker - With Amp     White - Brown     +,-     Amplifier on right rear cargo floor, black 28 pin plug, pins 26 - 25 (w/o JBL); pins 4 - 19 (JBL)
Right Front Speaker - With Amp     Red - Blue     +,-     Amplifier on right rear cargo floor, black 28 pin plug, pins 28 - 27 (w/o JBL); pins 1 - 2 (JBL)
Left Front Tweeter - With Amp     Red - Brown (w/o JBL)     +,-     Amplifier on right rear cargo floor, black 28 pin plug, pins 3 - 4 (w/o JBL)
Right Front Tweeter - With Amp     Brown - Blue (w/o JBL)     +,-     Amplifier on right rear cargo floor, black 28 pin plug, pins 1 - 2 (w/o JBL)
Left Rear Speaker - With Amp     Black - Yellow     +,-     Amplifier on right rear cargo floor, black 28 pin plug, pins 15 - 14 (w/o JBL); pins 13 - 26 (JBL)
Right Rear Speaker - With Amp     Green - Orange     +,-     Amplifier on right rear cargo floor, black 28 pin plug, pins 13 - 12 (w/o JBL); pins 12 - 25 (JBL)
Center Channel - With Amp     Red - Blue     +,-     Amplifier on right rear cargo floor, white 28 pin plug, pins 28 - 27 (w/o JBL); black 28 pin plug, pins 14 - 27 (JBL)
Subwoofer - With Amp     Green - Orange (coil 1); Blue - Red (coil 2)     +,-     Amplifier on right rear cargo floor, black 28 pin plug, pins 16 - 17; 18 - 19 (w/o JBL); pins 2 - 17; 1 - 16 (JBL)
Aux. Audio Input Left (+/-)     White or Red - Black/Orange     +,-     Radio, white 24 pin plug, pins 21 - 9 or white 38 pin plug, pins 24 - 25
Aux. Audio Input Right (+/-)     Black - Black/Orange     +,-     Radio, white 24 pin plug, pins 8 - 9 or white 38 pin plug, pins 10 - 25
Rearview Camera Video     Yellow - Brown     +,-     Radio, white 16 pin plug, pins 4 - 3 or white 38 pin plug, pins 7 - 21 or white 24 pin plug, pins 23 - 22
Gary Sather
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
