2021 Hyundai Kona, Spy LC095A1 Remote Start Install
c0ryp1
Member - Posts: 13
Posted: November 04, 2025 at 7:19 PM / IP Logged Link to Post Post Reply Quote c0ryp1
ok im runing out of hair to pull out with this one.
i have checked my ignition coils wiring with my dmm on the kona i see a black, red, white, purple, pink and green wires
no keys in i get black 0v red 12.2v white 0v purple 0v pink 0v green 12.2v
acc black 0v red 12.2v white 0v purple 12.2v pink 0v green 12.2v
run black 12.2v red 12.2v white 1v purple 12.2v pink 12.2v green 12.2v
start black drops to 0v red drops to 10v white jumps to 12v purple drops to 0v pink jumps to 10v and green drops to 10v
im telling myself red and green are battery +, purple acc, black on1, pink on2 white is starter feed
my starter brain has acc, on1,on2 and the one that has me stumped is this engine line what should it be connected too?
c0ryp1
Member - Posts: 13
Posted: November 20, 2025 at 9:54 AM / IP Logged Link to Post Post Reply Quote c0ryp1
Ok so basically I had ig1 and ig2 swapped car starter is running I paid for access to Hyundaitech website and now I see on I/p-D connector of the sjb pins 30 and 22 are unlock and lock my alarm brain seems to pull to ground which back probing(I don’t have enough of a length to back probe IP-D connector but at connector d02 in the door at the window lock module pins 6 and 4 control the lock unlock and I can see a constant 8v(weird I expected 12) which does drop to around 2 v when it gets a lock signal but attempting to briefly ground any of these pins does not cause the door to lock or unlock… befor I go to relays and tapping directly into the unlock motor am I missing something or is my car sending a pmw signal or something and that’s my issue?
