2002 Jeep Liberty Alarm Wiring
danm2a2
Posted: June 28, 2002 at 8:34 PM / IP Logged
Hey, I need the wiring diagram to install a security system into a 2002 Jeep Liberty. If there's a web site that has it let me know also. Thanks much, Dan.
Dan Bennett
Installation Tech
Electronic Engineering
Police/Ems Vehicle Bay
Moderator - Posts: 12,488
Posted: June 28, 2002 at 10:50 PM / IP Logged
Jeep
Liberty
2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
RED / BLUE
Ignition #2:
BLACK/ ORANGE
Ignition  #3:
N/A
Accessory:
BLACK/ WHITE
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
TAN/RED
AT COIL # 1
Parking Lights:
LT. GREEN/ ORANGE (-)
AT HEADLIGHT SWITCH
Headlights:
N/A
OEM Alarm  Disarm:
LT. GREEN/ ORANGE
DRIVER'S KICK PANEL ***
OEM Alarm  Arm:
LT. GREEN/ ORANGE
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
Notes:
 * This vehicle may be equipped with Chrysler's Smart Key Transponder Theft System Only If The Ignition Key Is Gray
Jeep
Liberty
2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
RED / BLUE
Dome  Lights/Superv:
YELLOW
AT COURTESY LIGHT UNDER DASH **
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
PINK/VIOLET
DRIVER'S KICK PANEL ****
Power  Unlock:
PINK/VIOLET
Trunk  Release:
ORANGE / BROWN (+)
AT BCM THAT’S INTEGRATED INTO THE FUSE PANEL
Alarm  Input Wire:
YELLOW
Notes:
** Use For Alarm Pulse Only. For Domelight Supervision, Use Either A Tan (-) or Tan/White (-) Wire Located In A Blue Plug To The Right Of The Steering Column. These Are The Driver's And Passenger Door Pulses Respectively. *** Single Wire System. A Negative Pulse Through A 475 Ohm Resistor Will Disarm The Alarm. A Negative Pulse Through A 2 K-Ohm Resistor Will Arm The Alarm. **** Single Wire System. A Negative Pulse Through A 1.4 K-Ohm Resistor Will Lock The Doors. A Negative Pulse Through A 425 Ohm Resistor Will Unlock All The Doors.
danm2a2
Posted: June 30, 2002 at 8:51 PM / IP Logged
Thanks much. Greatly appreciate the help. If you need something for police package vehicles or anything e-mail me at dbennett@connectingyou.com. We do all sorts of vehicles for undercover work and the like.  Again thanks alot, Dan Bennett.
Dan Bennett
Installation Tech
Posted: June 30, 2002 at 9:08 PM / IP Logged
Hey Dan, can you get me out of a speeding ticket ? 2002 Jeep Liberty Alarm Wiring - Last Post -- posted image. If you need anymore diagrams or help, just post and we'll see if we can help you out.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
