Push button switches
copcarguy
Copper - Posts: 122
Posted: July 01, 2003 at 8:44 PM / IP Logged
I need to find a supplier/manufacturer for N.C. momentary push button switches with a nice appearance. They only have to carry 5amps max. The trick is finding the normally closed type. Any help is appreciated.
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
TomEllis
Copper - Posts: 52
Posted: July 02, 2003 at 12:17 PM / IP Logged
Try NKK Switches at:
NKK switches
E-Switch at:
E-Switch
Digi-Key at:
Digi-Key
I know there are others, but this might be what you are looking for.
Good luck,
Tom
Push button switches - Last Post -- posted image.
ezridr
Copper - Posts: 127
Posted: July 02, 2003 at 9:32 PM / IP Logged
also radioshack.com
My mechanic told me, "I couldn't fix your brakes, so I made your horn louder"
Ronald Mark
Copper - Posts: 66
Posted: July 03, 2003 at 11:00 AM / IP Logged
Radio shack has some, but they are not enough aperage. Theses are nice and will hold up well. they are from : http://www.mcmaster.com
Style H switches are more durable than styles F and G thanks to a stainless steel and plastic housing that protects the internal mechanism. Plus, the small button size is perfect for panel mounting—especially if you don't have a lot of panel space. Ideal for marine applications. Rated 5 amps @ 120 VAC/28 VDC. Buttons are black plastic. Wire leads are 24" long.
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
