system help ?
fatdaddyjoe
Copper - Posts: 129
Posted: July 03, 2003 at 10:17 AM / IP Logged
would the audiobahn a18001dq amp and three audiobahn aw150q 15" subs work together as a set??????please let me know......
the louder the better !!!!!!
can you feel it ?????
esmith69
Gold - Posts: 1,511
Posted: July 03, 2003 at 11:44 AM / IP Logged
those are the 4-ohm voice coil DVC subs, right?  Assuming that's the case, you'll wire them up like this:
system help ? - Page 2 - Last Post -- posted image.
If they are actually SVC subs, you can still use that audiobahn amp cuz it's 1-ohm stable.  3 of the SVC subs would be hooked up like this:
Ethan
Donate to the12volt.com
fatdaddyjoe
Copper - Posts: 129
Posted: July 03, 2003 at 12:23 PM / IP Logged
yes they are svc and thanks for the help again.................................
fatdaddyjoe
Copper - Posts: 129
Posted: July 05, 2003 at 7:17 PM / IP Logged
ok i have decided on running 3 aw150q audiobahn subs that are svc 4 ohm subs is there any suggestions on a mono amp that is 1 ohm stable to run these subs for around $300-$350. if so please let me know......also can someone calculate the size box i should build for these subs?the best design with the right airspace..they are going in a 1991 chevy caprice......i cant figure out the calculations for airspace and all. i am going to wire the subs together inside the box so there is one soeaker hook-up on the back of the box......someone please help with the dimensions on a box....thanks again...
fatdaddyjoe
Copper - Posts: 129
Posted: July 06, 2003 at 11:58 PM / IP Logged
can someone recommend an amp for these subs????should i go with the audiobahn? also i am looking at a 2400 watt  concept cc-d2400a is this amp any good?????
thomasbutler
Copper - Posts: 91
Posted: July 07, 2003 at 9:19 AM / IP Logged
Like esmith said you could get 2 jbl 1200.1 amps and they would rock those 15's.  Trust me i own one of the 1200.1 models hooked up to 2 kicker cvr's and it had more than enough power to handle the kickers im scared to turn the amp up.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
