help! Starter does not turn off after
Rams Z
Member - Posts: 14
Posted: July 28, 2003 at 9:09 PM / IP Logged
I have a 98 Ford Ranger Truck with a Clifford Avant Guard 4 alarm I installed this weekend. I have all the different wiring diagrams for my truck and the complete 24 page install manual from Clifford. However, when the truck starts it does everything it is susposed to. Even the lights flash two times before the truck starts to indicate everything is fine, but after starting the starter is still engaged. The truck is running and the starter is still spinning and then after ten seconds the truck turns off and then does it all over again. Everything else works perfectly.
Why?
Am I an Idiot?
Please help
Basscoholic23
Copper - Posts: 67
Posted: July 29, 2003 at 12:06 AM / IP Logged
Most likely the problem is your remote start (ignition wire)is hooked up to your starter wire in your ignition switch harness (RED / light blue wire).
hope this helpshelp! Starter does not turn off after - Last Post -- posted image.
Rams Z
Member - Posts: 14
Posted: July 29, 2003 at 12:14 PM / IP Logged
Fixed it. I didn't learn the tach right the first time.  I'm an idiot.
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
