ignition 12v(+) Wire
Jdm R
Member - Posts: 14
Posted: July 31, 2003 at 11:51 PM / IP Logged
Where should i tap into the ignition 12v(+) Wire? as shown in this picture: ignition 12v(+) Wire - Last Post -- posted image.
and this pic: ignition 12v(+) Wire - Last Post -- posted image.
I have a 95 integra and i'm gonin to do a fuel kill switch shown in tha 2nd pic amd a starter kill switch in the 1st pic. where is the best place to tap into the ignition 12v(+) Wire so i can connect it to these switches?
1995 Integra LS 5 speed
-RSpec106@netscape.net
Jdm R
Member - Posts: 14
Posted: July 31, 2003 at 11:54 PM / IP Logged
here's the link to the 2nd pic that was soposed to be in the 1st post.
http://www.we-todd-did-racing.com/wetoddimage.wtdr?i=wMTM5NzYxNnM0MTNkZmQzMXk1NDE%3D
draasch
Gold - Posts: 2,172
Posted: August 01, 2003 at 4:52 AM / IP Logged
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Jdm R
Member - Posts: 14
Posted: August 01, 2003 at 4:55 PM / IP Logged
so i would cut the big white wire that is connected to the ignition switch. Also cut the starter wire that is BLACK/ white. These wires are next to BLACK / YELLOW, yellow, and WHITE/ yellow wires; they connect to the ignition (key switch) on the left side of the steering wheel.
Jdm R
Member - Posts: 14
Posted: August 01, 2003 at 5:09 PM / IP Logged
The white wire and the BLACK/ white wire connect to the under-dash fuse/relay box above where the SRS wires plug into the under-dash fuse/relay box.
so are those wires the right wires to cut?
draasch
Gold - Posts: 2,172
Posted: August 02, 2003 at 2:02 PM / IP Logged
no do not cut the white wire. you are just getting power from the white wire to work the relays. your starter wire will need to be cut.
Good Luck
David
Ace Security
813-376-9778
Tampa
Jdm R
Member - Posts: 14
Posted: August 02, 2003 at 9:05 PM / IP Logged
So how do i get power from the white wire if i don't cut into it??
unprofessional
Copper - Posts: 61
Posted: August 02, 2003 at 9:08 PM / IP Logged
You'll probably have to strip back some insulation and solder your power wire to the ignition wire and wrap with some electrical tape.
If there is another safe way of getting +12V from the ignition wire without soldering I'd love to hear it.
draasch
Gold - Posts: 2,172
Posted: August 02, 2003 at 10:22 PM / IP Logged
i didnt mean you couldnt tap into, you cant cut it in two.....
Good Luck
David
Ace Security
813-376-9778
Tampa
Jdm R
Member - Posts: 14
Posted: August 03, 2003 at 2:39 PM / IP Logged
oh ok i completely understand now thanks fo da info.
