bypass problem
dbsoundz
Member - Posts: 7
Posted: September 01, 2003 at 8:52 PM / IP Logged
I have a 99 Lincoln Navigator and one of the keys were lost. I recently installed a Viper 790XV and tested the remote start out with the DEI 555U and my only key in it, and it works fine. Is there another bypass out there that I don't need 2 keys to program the module? Will BypassKits.com Ford Bypass Kit work? I have never had any experience with their products. Thanks ahead of time.
draasch
Gold - Posts: 2,172
Posted: September 01, 2003 at 9:13 PM / IP Logged
im not sure , but they should have a number that u can call. try asking for dave
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
chuckles
Member - Posts: 39
Posted: September 01, 2003 at 10:09 PM / IP Logged
It takes 2 keys to program a Ford.
McFord
Member - Posts: 25
Posted: September 02, 2003 at 2:45 PM / IP Logged
the 555f would solve the problem with you having to use your only key, as it does NOT require a key in a box type thing, the only problem you have then is you cannot program the 555f without TWO programed keys....so either way you go, your gonna have to get another key....
the only way you could work around is the old school, take the chip outta the key method, but then you would have NO pats security, but you could just get a regular ol spare made and it would work......
i would just buy another key.......usually on ebay for pretty cheap....but you would have to have your dealer program it i think, since the programming method requires 2 keys.....
dbsoundz
Member - Posts: 7
Posted: September 03, 2003 at 9:55 AM / IP Logged
I guess I'll just have another key made.
elrayodesinaloa
Copper - Posts: 120
Posted: September 03, 2003 at 12:51 PM / IP Logged
Just disable it and get a set of regular keys. It'll be less expensive besides you've already got a security system.
floaterr
Silver - Posts: 383
Posted: September 03, 2003 at 1:10 PM / IP Logged
Anybody ever use the same key twice? See if it even notices?
McFord
Member - Posts: 25
Posted: September 03, 2003 at 1:48 PM / IP Logged
same key twice dont work....it wont program the key....even having both the keys on the same ring will sometimes mess it up, because it will read the first key you use twice........
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
