rs-850 lcd
almeida79
Member - Posts: 47
Posted: September 12, 2003 at 3:02 PM / IP Logged
Does anyone know if the autopage rs-850lcd remote start alarm, starter kill wire also act as an antigrind output or will i have to wire an output when running wire to the relay along side with the starter kill wire and isolate them from each other   thanks Jay
Jay
jrilla
Gold - Posts: 1,498
Posted: September 12, 2003 at 4:22 PM / IP Logged
I know for sure that the 750 model worked that way, so I assume that they kept that the same. I could not say for sure though, I havent tested an 850 out yet.
J Rilla
Owner/Installer
almeida79
Member - Posts: 47
Posted: September 12, 2003 at 5:13 PM / IP Logged
which way are you saying that the starter kill also acts as an antigrind or that i also have to wire an output while running wire to the relay.
Jay
jrilla
Gold - Posts: 1,498
Posted: September 12, 2003 at 7:03 PM / IP Logged
On the Rs-750, the Orange wire which is the (-) armed output which is your starter kill trigger, produces the (-) output when armed as well as when the car is running by the power of the remote starter unit, so the armed output will take care of the anti-grind relay as well as your starter kill.
J Rilla
Owner/Installer
almeida79
Member - Posts: 47
Posted: September 13, 2003 at 5:38 AM / IP Logged
Thanks for your help i'm sure it's the same way on the 850 lcd.rs-850 lcd -- posted image.
Jay
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
