Where to Order 5 Wire Door Lock Switch
mgpetersen
Posted: September 25, 2003 at 2:15 PM / IP Logged
Do you know where I can order a "5 Wire Alternating (+) 12 V DC" Door Lock switch as showen on this site under Door Locks.  I plan to add an additional Door Lock Switch near the tail gate door of my 1993 Ford Explorer.  It was not an option in 1993.
Mike Petersen
csorb
Copper - Posts: 317
Posted: September 25, 2003 at 3:47 PM / IP Logged
Try Autotechs 1-888-252-8324
auex
Platinum - Posts: 5,041
Posted: September 25, 2003 at 5:17 PM / IP Logged
Don't really need to order the five wire switch. Just get a three wire switch and two relays.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
ViperATC5
Copper - Posts: 202
Posted: September 25, 2003 at 6:31 PM / IP Logged
Any DEI dealer should carry the 451M 5 wire door lock module
geotexz71
Copper - Posts: 65
Posted: September 25, 2003 at 9:29 PM / IP Logged
I'm with ViperATC5, get a 451M! Made installation a snap in a 98 GM K1500!
rudbwoy69camaro
Silver - Posts: 350
Posted: September 26, 2003 at 6:41 AM / IP Logged
padawan
Copper - Posts: 215
Posted: September 26, 2003 at 7:25 AM / IP Logged
www.caralarmz.com you can either get a "DLR" for 7 bux or a Double Socket/Double Relay for like 11 bux...I like the double socket relay...
floaterr
Silver - Posts: 383
Posted: September 26, 2003 at 9:13 AM / IP Logged
He's right. It doens't make much sense to run thick wires to carry the current all the way back to the front (5 wires!).
If you have wired in an alarm then just tap into the lock unlock wires of the brain (green and blue) and run 2 wires back to a 2way momentary switch. Run the ground wire somewhere close to the switch and bingo. Locks controlled from the rear.
If you haven't wired in an alarm then look on this website on how to install the relays.
This will make it eaier to find a switch that works. You could try the dealer and just get a door switch and modify. www.autloc.com (no "K") has lots of switches. You just have to order from soemwhere else. so search autoloc sellers.
mgpetersen
Posted: September 27, 2003 at 8:22 PM / IP Logged
Thanks to all who helped me with advise!  I will use the 2 DLRs as suggested.
Thanks again!
Mike Petersen
