Kia Carnival Door Lock
paran0
Posted: October 15, 2003 at 7:48 AM / IP Logged
I need help with my door lock unlock on my Kia Carnival 2.9 TD. There is a user of this car ? I don't undestand what work the system. The colors of wires are differents about the Sedona. I have a 2-way alarm of Stell-Mate.
Thank you
pecas
Member - Posts: 7
Posted: October 24, 2003 at 7:14 PM / IP Logged
SPECIFIC VEHICLE ALARM FITTING INSTRUCTIONS REV. 00
www.cobra.it
Note: This information is not binding, therefore it must be considered only an example for installation purposes that must be executed
as per the instructions given on the product installation manual.
kicar99gbb.doc
MAKE KIA MOD. CARNIVAL YEAR 99 ® PETROL
DIESEL
ALARM/SIREN
POSITION
Position the compact alarms and the sirens in the engine compartment, on the
support of the shock absorber, driver’s side.
CENTRAL UNIT POSITION Position the modular systems and the modules on the left, under the dashboard,
driver’s side.
POWER SUPPLY + 30: connect to the 4 mm2 RED wire located in a multiway connector, in the fuse
box.
- 31: connect with a ring terminal directly to the car body.
IGNITION WIRE + 15/54: connect to the wire at the position marked "+15/54" directly in the wiring
harness coming out of the connector of the ignition key.
DIRECTION INDICATORS Connect to the GREEN wire at the position nr. 13 and to the LIGHT BLUE wire at
the position nr. 14 located in the 14 way white connector on the rear of the check
control.
ELECTRIC WINDOWS Front window, driver’s side:
cut the BLUE and WHITE wires located in the wiring harness coming out of the 9
way white connector on the push-button panel of the driver’s side door.
Front window, passenger’s side:
cut the RED / YELLOW and GREEN wires in the wiring harness coming out of the
12 way white connector, above the fuse box.
Rear window, driver’s side:
cut the RED and WHITE wires in the 10 way white connector coming out of the
push- buttons near the wing mirror.
Rear window, passenger’s side:
cut the GREEN/ YELLOW wires in the 10 way white connector coming out of the
push-buttons near the wing mirror.
CENTRAL DOORS LOCKING Negative control signal with wire interruption
It is necessary to cut the YELLOW/BLACK wire located at the position nr. 12 in
the 12 way white connector, behind the driver’s side sill cover, above the fuse box.
Please refer to the diagram nr. 61.
IMMOBILISATION POINT Fuel pump
If the vehicle has the inertial switch, it is suggested the interruption of one of the
two wires coming out from the same.
STARTER +50: Cut the wire located at the position marked "+50" directly in the wiring
harness coming out of the ignition key.
BONNET SWITCH Install an additional switch on the front headlamp support plate.
DOORS SWITCH Connect to the GREEN wire at the position nr. 1 in the 14 way white connector
located on the rear of the check control.
BOOT SWITCH Connect to the GREEN/ BLACK wire at the position nr. 8 in the 14 way white
connector located on the rear of the check control.
X
www.cobra.it
kicar99gbb.doc
FITTING DIAGRAM N° 61
ORANGE YELLOW/BLACK VIOLET/ORANGE
YELLOW/BLACK
Door switch
Central
doors
locking
unit
VIOLET
To make the central doors locking on
KIA CARNIVAL mod. 2000 (with serial radio control)
(for " Bridge" car alarms)
To make the central doors closing it is necessary to cut the YELLOW/BLACK wire located at the position
nr. 12 in the 12 way white connector behind the driver’s side sill cover, above the fuse box.
Note: On vehicles without radio control, install a 2 wires actuating device inside the driver’s side door.
this is the wiring color of cobra alarm the manual of alarm i need but i need scan
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
