2003 Dodge Durango
nuketea
Posted: October 28, 2003 at 3:09 PM / IP Logged
Trying to install daytime running kit and cb radio.  Looking for following wire colors/locations under dash:
(1) Constant +12V, (2) +12V when key is in ON position, (3) Ground (if a wire exists, otherwise will use metal frame), (4) Parking Lights, (5) Low Beam Headlight (or just Headlight on, not the high beams).
Found 2000 Durango wiring diagram.  Do not know if wire colors are the same.
//Nuke
NowYaKnow
Gold - Posts: 1,217
Posted: October 28, 2003 at 4:42 PM / IP Logged
2003 Dodge Durango
| ITEM | WIRE COLOR |POL| WIRE LOCATION | | 12V|pnk/blk & RED / lt blu|+ |ignition harness | | STARTER|yellow |+ |ignition harness | | IGNITION|blue |+ |ignition harness | | SECOND IGNITION|GREEN/ red (18 ga)|+ |ignition harness | | ACCESSORY|BLACK/ orange |+ |ignition harness | | SECOND ACCESSORY|green |+ |ignition harness | | POWER LOCK|WHITE/ green |*1 |conn. 2, pin 10 @ CTM *2 | | POWER UNLOCK|same wire | | | | LOCK MOTOR|ORANGE / black | |conn. 2, pin 4 @ CTM *2 | | UNLOCK MOTOR|blue | |conn. 2, pin 6 @ CTM *2 | | DISARM DEFEAT|pink/black | |conn. 2, pin 5 @ CTM *2 | | PARKING LIGHTS +|BLACK / YELLOW | |headlight switch | | PARKING LIGHTS -|RED / yellow | |conn. 1, pin 4 @ CTM *2 | | HEADLIGHTS|lt. GREEN/ orange |- |headlight switch | | DOOR TRIGGER|*3 |- |CTM *2 | | DOME SUPERVISION|use door trigger | | | | TRUNK/HATCH PIN|tan/black |- |conn. 2, pin 7 @ CTM *2 | | FCTRY ALARM ARM|lt. GREEN/ orange |*4 |conn. 2, pin 14 @ CTM *2 | |FCTRY ALRM DISARM|same wire | | | | TACHOMETER|*5 | |ignition coil | | SPEED SENSE|WHITE/ orange or blue| |conn. 2, pin 27 @ PCM *6 | | BRAKE WIRE|WHITE/ tan |+ |brake pedal switch | | HORN TRIGGER|BLACK/ red |- |steering column or CTM *2 | | WIPERS|purple(L), RED / gry(H|+ |steering column | | LF WINDOW UP/DN|lt. blue - white |A |driver window switch | | RF WINDOW UP/DN|brn/wht - pur/wht |A |driver kick panel | | LR WINDOW UP/DN|blu/wht - RED / blk |A |driver kick panel | | RR WINDOW UP/DN|gry/blk - grn/wht |A |driver kick panel | | RADIO 12V|pink |+ |radio | | RADIO GROUND|black |- |radio | | RADIO SWITCH|RED / white |+ |radio | | RADIO ILLUMINATE|white |+ |radio | | LF SPEAKER|lt grn/pu-lt grn/grn| |radio | | RF SPEAKER|lt blu/pu-lt blu/blk| |radio | | LR SPEAKER|wht/red - wht/blk | |radio | | RR SPEAKER|tan/pur - tan/blk | |radio |
Notes:
NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 Lock is negative trigger thru a 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays. *2 The Central Timer Module is in the driver kick panel. *3 The driver door trigger is tan in connector 2, pin 15. The passenger door trigger (and rears) is tan/red in connector 2, pin 13. Use both and diode isolate each. See directfax document #1076 for wiring information. *4 Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger thru a 1565 ohm resistor. MUST use relays. This wire will also lock the doors, and it will unlock with a double pulse. *5 On the 5.9L models use BLACK/ gray at the ignition coil. The 4.7L models have an ignition coil for each cylinder, use the wires that is NOT GREEN/ orange at one of the coils. *6 The Powertrain Control Module is on the passenger fender.
mcsScott
Posted: December 24, 2003 at 12:51 PM / IP Logged
The horn is still the black & red wire on the 2002-2003 Durango.
Scott
Saturday, May 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
