Remote Start on a Nissan
milgrad
Member - Posts: 11
Posted: November 02, 2003 at 6:31 PM / IP Logged
I just had a remote start installed on a 2004 Nissan Murano (Audiovox 2way remote start) and was wondering if with the AUX output of the alarm if it can be set to roll my windows up and down.  Any advice would be appreciated.
Justaguy
Copper - Posts: 112
Posted: November 02, 2003 at 6:54 PM / IP Logged
Not sure about the starter if it has validity outputs or not (when the output stays on as long as you hold the button), but the lock wires on the murano will roll the windows up and down with a pulse longer that 1/2 second. So then u can just tap into the lock wire with your aux outputs to do the windows.
milgrad
Member - Posts: 11
Posted: November 02, 2003 at 7:48 PM / IP Logged
Thanks...I did not install in myself...I had a stereo shop do it so I will call them.  Will I be able to control the windows both up and down or just one?  Currently with the factory remote I can hold the unlock button for several seconds and it will put the windows down.  I am unable to put them up with the remote.  I have to put the key in the door to raise them....
Justaguy
Copper - Posts: 112
Posted: November 02, 2003 at 8:04 PM / IP Logged
No prob, don't quote me on this for sure, but i do think that the windows go down as well with the unlock input wire. You could have the guys at the shop extend the lock pulse(if posible on that system, most are) which would roll the windows up on lock, and you could have your aux output hooked to the unlock to roll the windows down if it has a longer pulse, but it will also unlock the doors.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
