hidden starter kill, ghost switch
Sps70129
Copper - Posts: 55
Posted: November 19, 2003 at 11:47 AM / IP Logged
does anyone know of any slick ways of having a ghost switch for starter kill, also ways of hooking it up
thanks
Moderator - Posts: 12,488
Posted: November 19, 2003 at 12:01 PM / IP Logged
Tie it into your cigarette lighter. Install a push on push off switch on the backside of the lighter. You will need to fabricate your own bracket but it's not that hard.
Sps70129
Copper - Posts: 55
Posted: November 19, 2003 at 12:47 PM / IP Logged
thanks Jeff, quick question (maybe a stupid one) is there anyway i can do this and still use my lighter? and also how do i go about doing this?
thanks
Posted: November 19, 2003 at 11:27 PM / IP Logged
No, basically you loose the function of the lighter. The bracket you make has to be placed far enough back that when you depress the lighter, it will press the switch.
Sps70129
Copper - Posts: 55
Posted: November 21, 2003 at 4:50 PM / IP Logged
thanks jeff
auex
Platinum - Posts: 5,041
Posted: November 21, 2003 at 6:21 PM / IP Logged
How about if you cut the power wire going to the cig lighter, and wire it to a negative trigger passive starter kill? When you push the cig lighter in it will pass the ground and activate the relay allowing you to start the car. Think it will work?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
PatD
Member - Posts: 6
Posted: November 23, 2003 at 9:25 AM / IP Logged
Auex, it will work. Just disconnect the positive side of your cig lighter and use it as the trigger for your starter kill. The coil that heats will pass enough ground to sh*tch a relay. I have done a weird install with this one......lol
PatD
Member - Posts: 6
Posted: November 23, 2003 at 9:26 AM / IP Logged
but yes, you will lose functionality of your lighter.
tuneman
Member - Posts: 43
Posted: November 24, 2003 at 1:37 AM / IP Logged
You can basicly use any switch or button on your dash. Turn signal, rear defrost, parking light, head light, having to have the e-brake on, or off. Which ever button or switch you use just needs to trigger a relay to allow starting. Just reply with a "what if I used such and such a switch or button" and I can try to help.
lil_joker2k2
Copper - Posts: 119
Posted: November 26, 2003 at 3:56 PM / IP Logged
how can I do the E-Brake thing, I already have my seatbelt and cruise control, dont know how to do the e brake....its a 95 accord ex
Page of 3
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
