2003 Hyundai Tiburon
Welcome Guest :)
nei00755
Copper -
Posted: November 23, 2003 at 2:36 PM / IP Logged
I need alarm and remote start wiring diagrams for a 03 tiburon. any help would be appreciated. thanks
jeff
ck auto
Copper -
Posted: November 23, 2003 at 2:58 PM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | White (+) | Ignition switch harness |
Ignition #1: | | Red (+) | Ignition switch harness* |
Ignition #2: | | N/A | Ignition switch harness |
Ignition #3: | | N/A | Ignition switch harness |
Accessory: | | Pink (+) | Ignition switch harness |
Brake Light: | | White (+) | Brake pedal switch |
Tach Signal: | | White (AC) | 23 pin connector in passenger kick panel |
Parking Lights: | | Pink/Black & GREEN/ Oranger (+) | 22 pin connector @ BCM** |
Notes: | | *This vehicle is equipped with a transponder immobilizer system. Use Universal Alarm Bypass Module part # 2X402 where X can be any number or use vehicle specific bypass module part # 23554. **The Body Control Module (BCM) is part of the fure/relay box under the driver side dash. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | Red (+) | Ignition switch harness |
Starter Kill: | | White (+) | Ignition switch harness |
Ignition +12 | | Red (+) | Ignition switch harness* |
oEM Horn: | | GREEN/ Black (-) | Steering column harness |
Power Lock: | | Yellow (+) | 12 pin connector @ BCM*** |
Power Unlock: | | Blue (+) | 12 pin connector @ BCM*** |
Trunk Release: | | Blue (+) | Drivers kick panel |
Notes: | | ***The yellow wire will test when moving the driver lock knob, the blue wire will test when moving the passenger lock knob. See Note #201 Negative Trigger Door Locks |
hi here is the wireing be careful there is screw hidden behind panel below radio to take knee bolster off. sorry about the bold but i cant get it to turn off.
Saturday, May 11, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
