door locks in 99 grand am
billy1234
Member - Posts: 12
Posted: November 26, 2003 at 9:54 AM / IP Logged
I am trying to hook-up locks in a 1999 Pontiac Grand Am.  The remote start module im using only has negative outputs.  The last one I hooked up in one of these had the option of negative or positive.  I switched the output to positive and had to use relays to isolate the signal and a 1.5K ohm resistor on the unlock output.  This other unit does not have positive outputs and I do not want to use 4 relays.  Any advice on this would be very helpful.  Thanx
Clay
draasch
Gold - Posts: 2,172
Posted: November 26, 2003 at 10:12 AM / IP Logged
Power Lock WHITE DRIVER KICK #217
Power Unlock SINGLE WIRE SYSTEM PANEL **
Doorlocks Are Found As A Single Wire System. A Negative Pusle On The WHITE Wire In The Driver Kick Panel Will Lock The Doors. A Negative Pulse Thru A 1.5K Ohm Resistor On The Same WHITE Wire Will Unlock The Doors
if your output is neg., then you wont need relays.....the car uses a neg input for the door locks
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
