Tach Wire for 2000 f150
Actuator
Member - Posts: 11
Posted: December 14, 2003 at 9:45 PM / IP Logged
Okay I have hunted for too long now.  I have checked #48 of 104 at ECM and also tried the wire that was not RED / grn at the injectors.
any help would be awesome.
thanks.
Primal Autosound & Security
Abbotsford, B.C. Canada
Actuator
Member - Posts: 11
Posted: December 14, 2003 at 10:05 PM / IP Logged
UPDATE:
I have also now tested #78 of the 104 at ECM as was directed by http://www.rostra.com
anybody?
CBS Installs
Member - Posts: 7
Posted: December 17, 2003 at 3:44 PM / IP Logged
have you tried going to the coil ?     try pink white.
Regards,
Craig Stevens
CBS Installations Drayton Valley AB
(780)621-1302
1kewlexpo
Member - Posts: 33
Posted: December 18, 2003 at 1:22 AM / IP Logged
4.6 L -- Go to any of the 8 ignition coils and use the wire that is not RED / green.
5.4 L -- it's the lt. GREEN / WHITE at the coil on the passenger side of the motor between the fuel injectors.
John
wiretapper
Copper - Posts: 166
Posted: December 18, 2003 at 12:01 PM / IP Logged
Slice open the thick loom on the pass. side firewall and get the pink/wht coming from the PCM.  Works every time.
Actuator
Member - Posts: 11
Posted: December 20, 2003 at 6:31 PM / IP Logged
Thanks for the tips everyone.  Just for reference for other people:
There was no pink white wire in the f150 i was working on,
It is easier and works just as well to go to one eight coils and tap the wire that is NOT RED / green.
hope someone else benefits from this info.
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
