2002 Dodge Stratus wiring info
allstarauto
Posted: December 19, 2003 at 1:09 PM / IP Logged
I need the diagram for a 02 Dodge Stratus SEDAN the only one in here is for a coupe. It looks like I missed the 4 door listing by like almost a year! Any help will be greatly welcomed!!
Geeque
Silver - Posts: 310
Posted: December 24, 2003 at 10:18 AM / IP Logged
Just did one of these last nite, It was easy:
2002 DODGE STRATUS 4DR SEDAN        SecurityBattery     WHT/RED +    (+)   IGNITION SWITCH HARNESSIgnition    GRN      (+)   IGNITION SWITCH HARNESSStarter01   BLK/RED +       (+)   IGNITION SWITCH HARNESSAllDoorTrigger       (-)FrontLeftDoorTrigger        GRN/YEL   -   DRIVERS KICK PANEL (ALL COMMON)FrontRightDoorTrigger      GRN/YEL   -   DRIVERS KICK PANEL (ALL COMMON)RearLeftDoorTrigger   GRN/YEL   -RearRightDoorTrigger       GRN/YEL   -   DRIVERS KICK PANEL (ALL COMMON)TrunkTrigger   RED / GRN -      (-)    @ TRUNK LIGHTFactoryAlarmDisarm   ORG -    DRIVERS KICK PANELFactoryAlarmArm   LT.GRN/BLK -      DRIVERS KICK PANELParkingLights   PNK/BLK +  (+)   PIN 6 OF 38 PIN CONN. @ CENT. JUNC. BOXLowCurrentParkingLights  GRN      -Remote StartBattery     WHT/RED +    (+)   IGNITION SWITCH HARNESSIgnition    GRN      (+)   IGNITION SWITCH HARNESSIgnition02        BLU/RED +      (+)   IGNITION SWITCH HARNESSIgnition03   +Accessory01   BLU/BLK +       (+)   IGNITION SWITCH HARNESSAccessory02       +Starter01   BLK/RED +       (+)   IGNITION SWITCH HARNESSAntiTheftType   RF ACTIVATED SYS.AntiTheftSystem     TRANSPONDER USE ASTCBM AND FACTORY PROGRAMMED KEYKeySense    (-)Tach     BLK/BLU 2.4 A  (AC)  PIN 10 OF 26 PIN @ PCM, 3.0 PIN 11 OF 35CrankShaftSensor     GRN/RED 2.4 MT   AC    =89-PCM.2.4AT=45-PCM.3.0 =43-PCMCamShaftSensor    BLU/YEL 2.4 MT     AC    =88-PCM.2.4AT=56-PCMSpeedSense   WHT/BLU 2.4 M      (AC)        =86-PCM.2.4 AT=80-PCM.3.0=80-PCM. ParkingLights   PNK/BLK +       (+)   PIN 6 OF 38 PIN CONN. @ CENT. JUNC. BOXLowCurrentParkingLights  GRN      -BrakeLights     GRN/ORG +    (+)   @ BRAKE SWITCHReverseLights        RED / BLU +  (+)   9 OF 43 IN-LINE CONN. UNDER L/H OF DASHHorn     LT.GRN/BLK -      STEERING COLUMN     Doorlocks / WindowPowerUnLock   BRN -    (+)   DRIVERS KICK PANELPowerLock      GRN -    (+)   DRIVERS KICK PANELDriverDoorMotor01   GRN/RED REV    @ JUNCTION BLOCKDriverDoorMotor02   LT.GRN REV        @ JUCTION BLOCKPassengerDoorMotor01    BLU/BLK REV      @ JUNCTION BLOCKLeftFrontWindow01   RED / BLK    +LeftFrontWindow02   GRN/BLK   +     DRIVERS SWITCHRightFrontWindow01        RED / WHT        +     DRIVERS SWITCHRightFrontWindow02        GRN      +     DRIVERS SWITCHLeftRearWindow01   GRN/BLK +RightRearWindow01   DRIVERS SWITCHSunRoofMotor01    GRN/RED   -   SUNROOF SWITCHSunRoofMotor02    GRN/YEL   -   SUNROOF SWITCHDoorlocks / WindowsPower UnLockUSE 750 OHM RESISTORPowerLockUSE 1.8KOHM RESISTORConvenienceFrontLeftParkLightBulb     PNK/BLK    +     @ FUSE PANELFrontRightParkLightBulb   GRN/WHT        +     @ FUSE PANELRearLeftParkLightBulb      PNK/BLK    +     @ FUSE PANELRearRightParkLightBulb   GRN/BLK   +     @ FUSE PANELHazardFrontLeft     GRN/BLU   +     PIN 17 OF 18 PIN BLK CONN @ RR OF JUNC.HazardFrontRight   GRN/YEL   +     PIN 18 OF 18 PIN BLK CONN @ RR OF JUNC.HazardRearLeft      GRN/BLU   +     PIN 17 OF 18 PIN BLK CONN @ RR OF JUNC.HazardRearRight   GRN/YEL   +     PIN 18 OF 18 PIN BLK CONN @ RR OF JUNC.LowSpeedWipers   BLU/ORG +    WIPER MOTORMobile Audio / VideoBattery     WHT/RED +    (+)   IGNITION SWITCH HARNESSAccessory01   BLU/BLK +       (+)   IGNITION SWITCH HARNESSGround     -Control ModulesUNDER PASS SIDE DASH
Gary Kline
MECP Master Technician
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
