Mitsubishi Galand ES 2000
mike08401
Member - Posts: 33
Posted: December 28, 2003 at 6:23 PM / IP Logged
Hi all!
I need diagram for Mitsubishi Galand ES 2000 I try to install the Crimestopper autostart and alarm but i can find the diagram for this especially I can not find the wire to disable factory keyless entry
Thank for your help
Teken
Gold - Posts: 1,492
Posted: December 28, 2003 at 6:31 PM / IP Logged
Mitsubishi
Galant
1999-2002
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   BLACK / YELLOW
IGNITION SWITCH HARNESS *
Ignition #1:
   BLACK/ WHITE
Ignition #2:
   BLUE/RED
Ignition #3:
   N/A
Accessory:
   BLUE/BLACK
Brake Light:
   GREEN/ 2 SILVER BARS
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   WHITE
IN CONN. NEXT TO FUSE BOX UNDER HOOD
Parking Lights:
   GREEN / WHITE (+)
BY FUSE BLOCK DRIVER'S SIDE DASH
Headlights:
OEM Alarm Disarm:
   BROWN / WHITE (-)
IN LOWER KICK PANEL/HARNESS FROM TRUNK
OEM Alarm Arm:
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * This vehicle may be equipped with a transponder immobilizer system. See Installation Note #144 - Bypassing Transponder Theft Systems.
Mitsubishi
Galant
1999-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   BLUE / YELLOW
Starter Kill:
   BLACK / YELLOW
Ignition +12 Volts:
   BLACK/ WHITE
Dome Lights/Superv:
   ORANGE / BLACK
DR. KICK PANEL LOW/HARNESS FROM TRUNK
OEM Horn:
   GREEN / WHITE (-)
STEERING COLUMN HARNESS
Power Lock:
   VIOLET (-)
IN DR. KICK PANEL/HARNESS FROM DOOR **
Power Unlock:
   LT. GREEN/ RED (-)
Trunk Release:
Alarm Input Wire:
   ORANGE / BLACK
Notes:
** See Note #201 - Negative Pulse Door Lock Diagram
Friday, June 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
