2001 GMC Sierra Alarm/Remote Start Wirring
Welcome Guest :)
ld9297
Member -
Posted: January 15, 2004 at 8:21 AM / IP Logged
does anybody have a wirring diagram for a 2001 gmc sierra i am trying to hookup a remote starter thanks in advance
boomer_106
Silver -
Posted: January 15, 2004 at 11:06 PM / IP Logged
GMC | Sierra Pickup | 1999-2002 |
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | YELLOW (# AWG) | IGNITION SWITCH HARNESS * |
Ignition #1: | | PINK (# AWG) | IGNITION SWITCH HARNESS |
Ignition #2: | | WHITE (# AWG) | IGNITION SWITCH HARNESS(ECM) |
Ignition #3: | | N/A | |
Accessory: | | ORANGE | IGNITION SWITCH HARNESS (HEAT/AC) |
Brake Light: | | WHITE (+) | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | VIOLET/WHITE | AT PLUG ABOVE VALVE COVER ON DR. SIDE |
Parking Lights: | | BROWN (+) | # PIN PLUG IN FUSE PANEL ON DR. SIDE |
Headlights: | | YELLOW (+) | AT HEALIGHT SWITCH |
OEM Alarm Disarm: | | GREEN | IN FLAT CONNECTOR IN DR. KICK PANEL |
OEM Alarm Arm: | | N/A | NO OEM ALARM PRESENT |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * This Vehicle Is Equipped With GM's PASSLOCK II Anti-Theft System; See Note #113. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | RED (2) | IGNITION SWITCH HARNESS |
Starter Kill: | | YELLOW (# AWG) | IGNITION SWITCH HARNESS * |
Ignition +12 Volts: | | PINK (# AWG) | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | WHITE | AT PLUG IN CONVIENENCE CENTER ** |
OEM Horn: | | BLACK (-) | STEERING COLUMN HARNESS |
Power Lock: | | L BLUE | # PIN PLUG AT FUSE PANEL ON DR. SIDE |
Power Unlock: | | WHITE | DRIVER'S KICK PANEL IN BODY CAVITY *** |
Trunk Release: | | N/A | |
Alarm Input Wire: | | WHITE | AT PLUG IN CONVIENENCE CENTER ** |
Notes: | | ** Convenience Center Is Locate Under Driver's Dash Near Fire Wall (Listen for dome light relay). *** See Note #202 - Positive Pulse Door Lock Diagram. |
ld9297
Member -
Posted: January 16, 2004 at 1:04 AM / IP Logged
boomer_106 just wanted to thank you for your reply this will do it and also thanks for the quick response
boomer_106
Silver -
Posted: January 16, 2004 at 9:59 PM / IP Logged
Your welcome. Good luck with your install and thanks for showing your appreciation.
Saturday, May 18, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
