Internal Bracing FG enclosures?
staudio
Member - Posts: 41
Posted: February 02, 2004 at 1:24 PM / IP Logged
If you've got flat areas that need reinforcment just use some string (heavy duty cloth strings, like cloths lines work well for me), soak them in resin, lay them on the internal area that is flat and fiberglass over them. This will add a slight but very ridged curve to a flat area allowing the outside to remain flat.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
