bridged or stereo?
pixiesfan78
Member - Posts: 14
Posted: February 09, 2004 at 1:05 AM / IP Logged
hows it. i need to know if i should bridge this amp to get the most bang out of it. it is an audiobahn a275hcq high current amp. also i have 2 aw125t subs the amp runs 75 watts rms the subs say 400 rms. so if i do bridge the amp should i wire the subs in series or paralell.thanks alot.
love the flames.apair of aw1251t subs 75 watt rms flame amp eq/linedriver clarion h.u.the rest is temporary untill i can afford the rest of the system.
staudio
Member - Posts: 41
Posted: February 09, 2004 at 2:14 AM / IP Logged
I had a pair of AW1251T's, they're DVC subs and the A275HCQ amp is 2 channel right? Assuming the Amp is 2-Ohm stable (most audiobahns are...) I'd wire each sub in parallel between the 2 voic coils and run one sub off each channel, if the amps rated at 2x75 @ 4-Ohm it will put out about 100-150 Watts per channel at 2-Ohm which will push those subs fairly well.
pixiesfan78
Member - Posts: 14
Posted: February 09, 2004 at 2:21 AM / IP Logged
hey cool i appriciate it a lot.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
