need relay diagram
markcars
Silver - Posts: 662
Posted: March 12, 2004 at 4:47 PM / IP Logged
Can someone tell me how to connect a relay or two, so that I get the following:
12v from RS unit must go directly to IGN1 of car
12v from IGN2(key) goes to IGN2 when car is running via RS.
the trick/problem is you cannot let voltage from RS go to IGN1 via relay, it has to have a direct connection.
thanks to anyone who can show me how.
popeye004
Copper - Posts: 97
Posted: March 12, 2004 at 7:09 PM / IP Logged
what are you trying to do?
markcars
Silver - Posts: 662
Posted: March 12, 2004 at 8:01 PM / IP Logged
I wrote what I want to do in my post. I want a 12v to go straignt to my IGN without a break, and I want a second 12v to go to IGN2 only when started via the Remote Start.
auex
Platinum - Posts: 5,041
Posted: March 12, 2004 at 8:17 PM / IP Logged
Why does this have to be a direct connection?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
markcars
Silver - Posts: 662
Posted: March 13, 2004 at 7:02 AM / IP Logged
auex, it has to be a direct connection because my RS unit uses its IGN wire both as an output and and input sensing wire. If I isolate it via a relay it won't be getting the input signals both while armed and disarmed and programming.
I am at the point I am regretting getting my RS/Alarm unit. I should have probably gotten a different one. Well life is such. We learn with knocks and blows and at a cost, most of the times. The good thing is I won't fall in the same trap twice.
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
