2003 f-150 power wire connect under hood
phuddleston
Posted: March 21, 2004 at 5:09 PM / IP Logged
When I connect thispower wire, will I be better off to connect directly to the battery, or would I connect to what appears to be some sort of factory distribution terminal attached to the firewall almost directly behind the battery.  There only seems to be about 12 - 18 inchec of wire separating the battery from this location.  The system will be extremely modest and will just be a couple hundred watts of power for a 10" sub.  The power wire is 4 Ga.
Thanks in advance.
Paul
stevdart
Platinum - Posts: 5,816
Posted: March 21, 2004 at 8:42 PM / IP Logged
Always connect directly to the positive battery terminal.
jbjohn22jb
Member - Posts: 38
Posted: March 21, 2004 at 8:51 PM / IP Logged
If I can add one more thing......Don't forget the inline fuse. But I guess that goes without saying.
"I'm only doin' this for ya because I heard that Buffalo Bob guy shoved a road flare up yer bunghole...."
Kenwwod 315s
2 Audiobahn AWI25IT
1 Audiobahn A275HCT
1 Tsunami 1.0
1 Legacy 3.0
auex
Platinum - Posts: 5,041
Posted: March 21, 2004 at 9:05 PM / IP Logged
Always from the battery with a fuse or circuit breaker.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Saturday, June 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
