whinning coming out of the speakers
xTimx
Copper - Posts: 354
Posted: April 02, 2004 at 10:44 AM / IP Logged
quick, i'm hooking up my bros new stereo, now there is a whinning coming out of the speakers? whats the solution!?
xTimx
DYohn
Moderator - Posts: 10,741
Posted: April 02, 2004 at 11:05 AM / IP Logged
Whining is usually caused by a grounding issue, or by a speaker wire touching ground, or by a defective car electrical system.
xTimx
Copper - Posts: 354
Posted: April 02, 2004 at 2:24 PM / IP Logged
ok i connected everything replaced a fuse and there is STILL engine noise! when all the grounds (amp ground and head unit ground) are clean and properly installed.
xTimx
DYohn
Posted: April 02, 2004 at 2:30 PM / IP Logged
Are you useing the factory ground in the wiring harness for the head?  Try grounding it directly to the chassis.  Is it a Pioneer head?  What fuse did you need to replace?
netboy
Copper - Posts: 108
Posted: April 02, 2004 at 3:17 PM / IP Logged
are your power and rcas ran on opposite sides of the car?  If they are next to each other noise from the power wire can enter the rcas and cause the whinning.
Memphis MC-1300
2 12" JLw6v2
Diamond audio M3 6x9
Diamond audio M3 5.25 components
Audio control Matrix
Carputer
xTimx
Copper - Posts: 354
Posted: April 03, 2004 at 12:22 PM / IP Logged
its an old 2002 sony xplod cassete deck with cd changer in the back i really dont know the model #, but before my brother said when you take of the face plate it used to whine but when you put it back on it doesnt. but now when i hooked it up it was whinning at first i check the RCA's and it would only whine when i plug the RCA's to the 4ch amp to the front side. now i looked on the sub amp that FUSE was blown. i replaced it. hooked everything back up again and it was working fine, but it was whinning off and on. and yes RCA's and power are runnning on opposite sides. BUT, in order to accomodate for the wire i had to use, i had to put the Distro block right beside the two amps, RCA's are right next beside it as well as just one speaker wires are running for the subs. could this be the prob!?
xTimx
DYohn
Posted: April 03, 2004 at 2:09 PM / IP Logged
2002 is not exactly OLD, but it sounds to me like the head unit is the problem.  Try running a new seperate ground for the HU to the chassis and see if it helps.
xTimx
Copper - Posts: 354
Posted: April 03, 2004 at 6:40 PM / IP Logged
well my bro got his stereo fixed...:S wtf i said lol, apparently it was the equalizer he had...i dont get it, lol but the equalizer was hooked up (remote, power and ground) to one of the other amps. :S thats really wierd for me to know! never heard of that one
xTimx
DYohn
Posted: April 03, 2004 at 6:44 PM / IP Logged
Ah, you didn't mention an EQ.  ALWAYS list all the equipment in your system, please, as it really helps and saves time!  In MANY systems, an EQ is a cause for whine, especially older or cheap EQs used with newer heads.  Toss it into the garbage (or sell it on eBay.)
xTimx
Copper - Posts: 354
Posted: April 03, 2004 at 6:50 PM / IP Logged
lol! well..shhh keep this between each other...lol,..i accidentally, well, broke his EQ >< i bent the RCA inputs and broke them! BY ACCICENT! i swear! lol
xTimx
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
