2003 Dodge Durango Wiring Info?
Welcome Guest :)
Dragorus
Copper -
Posted: April 04, 2004 at 3:51 PM / IP Logged
I need a wire sheet for a 2003 durango.......If someone could post a good one it would be appreciated.....
bmf1000d
Silver -
Posted: April 04, 2004 at 3:58 PM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | Vehicle Color | Location |
Start: | | Yellow (+) | Ignition switch harness |
Ignition #1: | | Blue (+) | Ignition switch harness* |
Ignition #2: | | GREEN/ Red (+) | Ignition switch harness |
Ignition #3: | | RED / White (+) | Ignition switch harness |
Accessory: | | BLACK/ Orange (+) | Ignition switch harness |
Brake Light: | | WHITE/ Tan (+) | Brake pedal switch |
Tach Signal: | | See note | At ignition coil** |
Parking Lights: | | BLACK / YELLOW (+) | Headlight switch |
Headlights: | | | |
OEM Alarm Disarm: | | Lt.GREEN/ Orange (-) | Pin 14 @ CTM*** |
OEM Alarm Arm: | | Lt.GREEN/ Orange (-) | Pin 14 @ CTM*** |
Diesel Glow Plug: | | | |
Clutch Bypass Wire: | | | |
Notes: | | * If this vehicle has a gray ignition key, then it is equipped with a Transponder Immobilizer System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number, or use vehicle specific bypass module part # 23568. **On the 5.9L models use BLACK/ Gray at the ignition coil. The 4.7L models have an ginition coil for each cylinder, use the wire that is not GREEN/ orange at one of the coils. ***The Central Timer Module (CTM) is in the drivers kick panel. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | Pink/Black & RED / Lt.Blue | Ignition switch harness |
Starter Kill: | | Yellow (+) | Ignition switch harness |
Ignition +12 Volts: | | Blue (+) | Ignition switch harness* |
Dome Lights/Superv: | | | |
OEM Horn: | | BLACK/ Red (-) | Steering column harness or at CTM**** |
Power Lock: | | WHITE/ Green (-) | Pin #10 at the CTM***** |
Power Unlock: | | WHITE/ Green (-) | Pin #10 at the CTM***** |
Trunk Release: | | | |
Alarm Input Wire: | | | |
Notes: | | ****The Central Timer Module (CTM) is in the drivers kick panel. *****Lock requires a negative trigger through a 820 ohm resistor. Unlock requires a negative trigger through a 330 ohm resistor. See Note #211 Negative Trigger Single Wire Door Locks |
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Dragorus
Copper -
Posted: April 04, 2004 at 4:04 PM / IP Logged
bmf1000d
Silver -
Posted: April 04, 2004 at 5:42 PM / IP Logged
no problem
"Big" Mike
Double Take
Fremont, Ne
Sunday, May 12, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
