so called manual mode for auto start
Pooreclipse
Copper - Posts: 75
Posted: April 16, 2004 at 3:13 PM / IP Logged
So I noticed some of these alarm claims to have a manual transmission compatibility, it seems it's really only enforcement, where it makes you exit the car and will not shut off the engine until you close the door.
If you try it any other way, the remote start will not be be possible to use.   That way no one can every park it in gear.  Well almost.  Unless you climb out the window. hehe.
My question is if the DEI alarms has it because it claims to be for automatic cars only
Trav3D1
Copper - Posts: 146
Posted: April 16, 2004 at 4:00 PM / IP Logged
Yes, I believe that DEI does make an alarm for manual transmissions.  I forgot which one, but it's one of the Clifford models.
Trav
kgerry
Platinum - Posts: 3,455
Posted: April 16, 2004 at 4:46 PM / IP Logged
not anymore they dont... as of the G5 line they want nothing to do with manuals, although i understand the remote IS module from the G4 will work still
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
jayts95
Copper - Posts: 150
Posted: April 16, 2004 at 7:45 PM / IP Logged
The Clifford G5 series still is capable of manual transmissions. I have done quite a few of them already. There is still the wire that you have to ground if it is an automatic. The G5's are also very simple to install.
auex
Platinum - Posts: 5,041
Posted: April 16, 2004 at 7:51 PM / IP Logged
All remote starts are capable of starting a manual transmission. That doesn't make them safe.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Trav3D1
Copper - Posts: 146
Posted: April 19, 2004 at 8:49 AM / IP Logged
The last reply is correct.  All remote stats are capable of starting a manual transmission.  I would suggest finding a remote start that is specifically made for manual transmissions.  Should you install a remote start that is for automatic transmissions, you take the risk of the vehicle being able to start while in gear.
Trav
spyderman_maryj
Member - Posts: 15
Posted: April 20, 2004 at 12:46 PM / IP Logged
I have a RS installed in my Eclipse 5sp and it works fine.  IT works like you described... but if I want to park it in gear (ie. on a hill...) once I remove the key, I tap the brakes two times and it will shut off the car, and cancel the reserve mode (it cannot be remote started again until I start the car, turn off key.....)  But you want to make sure you use one designed for manual trans. or else it can be dangerous!
Thursday, May 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
