toyota (rav-4)
604customs
Member - Posts: 22
Posted: April 21, 2004 at 8:37 PM / IP Logged
hi,  does anybody have a wiring diagram for a 1998 toyota rav 4.
thanks ...
604
mo12v
Posted: April 21, 2004 at 10:13 PM / IP Logged
12 Volt       White(Fused 10 amp) & BLACK/ Red(Fused 5 amp)   Ign Harness
Ignition        BLACK/ White        Ign Harness
Ignition 2     BLACK / YELLOW        Ign Harness
Ignition 3
Accessory   Blue/Red        Ign Harness
Starter          Red (AT)  BLACK/ White (MT)                                           Ign Harness
Dome Lt.     RED / Yellow (-)                            7 pin Orange Conn. at Fuse Block*
Parking Lt   Green (+)                                   11 pin Orange Conn. at Fuse Block
Lock             Blue/White (-) Pulse               16 pin Blue Conn. in Driver Kick Pan**
Unlock         Blue/Yelow (-) Pulse               16 pin Blue Conn in Driver Kick Pan**
Brake Lt      GREEN / WHITE (+)                                 Switch above Brake Pedal
*   RED / Yellow covers Front Doors Only, RED / White Wire covers Rear Doors.
**  Child Door Safety Door Lock Circuit
MO
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
