97 Chevy Z71 Remote start problem
popeye004
Copper - Posts: 97
Posted: April 21, 2004 at 9:02 PM / IP Logged
Can anyone help me out I have a 97 Chevy Z71 pick up and its got a hornet 553T remote start/alarm and when I press the button to start it it does not start I hear the fuel injector hiss the headlights go on and all acc. lights but just doesn't cran over can anyone tell me whats going on.
italnpimp59
Silver - Posts: 427
Posted: April 22, 2004 at 6:14 PM / IP Logged
sounds like passlock is not bypassed correctly..how exactly did u do the bypass?
popeye004
Copper - Posts: 97
Posted: April 22, 2004 at 7:16 PM / IP Logged
it was working and orked good for about 4 years now it just stoped.
tjdurham
Copper - Posts: 180
Posted: April 22, 2004 at 7:20 PM / IP Logged
there is no passlock in97 check the starter relay in the ribbon cable harness its the one with the purple wire in it just pull the relay out and put in a new one if you dont have a relay switch with the accessory relay on the orange wire it wont hurt anything but if it works get a new relay asap
tj
popeye004
Copper - Posts: 97
Posted: April 22, 2004 at 8:56 PM / IP Logged
yeah there are 4 relays there. So just take out the relay with the purple wire in it and put a new one in, are all relays the same I have a 30amp bosch relay will that be the same.
popeye004
Copper - Posts: 97
Posted: April 22, 2004 at 8:57 PM / IP Logged
well there is only 3 in the triple relay harness and an addition relay for I don't know what.
popeye004
Copper - Posts: 97
Posted: April 23, 2004 at 10:02 PM / IP Logged
the purple wire has +12 volts in it all the time, I don't think this is normal and my LED when I start my truck with my key it flashes 3 time it use to flash 6 times before anyone have any idea whats up.
CCroadshoptn
Copper - Posts: 67
Posted: May 27, 2004 at 1:17 AM / IP Logged
It may be wired up wrong and worked for a little while then burnt out the relays. You should only have 12v to the starter wire (purple) while cranking the engine, no other time. Test the other wires to see if they are getting 12v only when cranking and rewire accordingly
Mecp Certified
Double check advice with your Meter.
tjdurham
Copper - Posts: 180
Posted: May 27, 2004 at 7:31 AM / IP Logged
take a jumper and ground  the purple ribbon wire if it cranks the starter your relay and wires are good ,you will have 12 v at the ribbon but they go to lo current ground when starting
tj
kgerry
Platinum - Posts: 3,455
Posted: May 27, 2004 at 9:53 AM / IP Logged
3 flashes denotes tach lockout...recheck your tach wire to see if it's still connected...if you soldered it under the hood you may have to redo it if it has corroded at the connection.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
