alternator big enough?
Thedfndent
Member - Posts: 31
Posted: April 28, 2004 at 10:48 AM / IP Logged
I need to upgrade my alternator in my 93 accord so that I can run a PPI PCX-1500 which puts out 1000W RMS.  Also i got an amp for my highs which puts out 120W RMS (not really a big deal).  The answer I'm getting from a local shop is that the best he can do is a 120-amp alternator, anything higher will require brackets, etc.  I was looking for 135amps,  Any opinions on whether 120-amps will be sufficient to run the car, ac, rear defrost, audio system, and still charge the battery?
2 12" L7's
PPI PCX-1500
4 6.5" Pioneer 4-way's
Kenwood KAC-6401
Lanzar Opti-Drive Cap
Sony CDX-F7700 Headunit
Sebastian018
Silver - Posts: 364
Posted: April 28, 2004 at 1:29 PM / IP Logged
HOw many amp is your stock alternator?
forbidden
Platinum - Posts: 5,352
Posted: April 28, 2004 at 1:32 PM / IP Logged
Go big or go home, what happens in the future if you want to add another amp or more subs? Find a bigger alternator if possible.
Thedfndent
Member - Posts: 31
Posted: April 28, 2004 at 2:11 PM / IP Logged
Sebastian: My stock alt is 85 amps.  Forbidden: I defininetly wont be adding any more equipment to my car.  I'll buy a new car before I sink any more than I already have into this one. Plus I think two 12" L7's is plenty for my ears.
2 12" L7's
PPI PCX-1500
Kenwood KAC-6401
forbidden
Posted: April 28, 2004 at 2:26 PM / IP Logged
WHAT'S THAT... I CAN'T HEAR YOU OVER THE BASS. DID YOU SAY L7'S? It should play plenty loud for you. Don't spend the extra dollars then having a custom fabrication done. Have a closer look around for a bolt on option and see what you come up with.
jeffchilcott
Platinum - Posts: 2,483
Posted: April 28, 2004 at 9:25 PM / IP Logged
try ohio generators they make alternators for about every vehicle or can make one and not at that bad of a price
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
