2000 Stratus Wiring Chart
Welcome Guest :)
mito57
Member -
Posted: May 14, 2004 at 6:47 PM / IP Logged
I' installing a remote start-alrm and keyless unit in a 2000 Stratus sedan. Can anyone give me a wiring chart. Im a beginner in this issues.
rudbwoy69camaro
Silver -
Posted: May 14, 2004 at 11:38 PM / IP Logged
2000 Dodge Stratus Item | Wire Color | Polarity | Wire Location |
12V | red, pink/black *1 | + | ignition harness |
STARTER | yellow | + | ignition harness |
IGNITION | dark blue | + | ignition harness |
ACCESSORY | BLACK/ orange | + | ignition harness |
SECOND ACCESSORY | GREEN/ red | + | ignition harness |
TACHOMETER | BLACK/ gray | | coil pack *2 |
POWER LOCK | WHITE/ green *3 | + | rear of fuse box under dash |
POWER UNLOCK | same wire | | |
PARKING LIGHTS + | BLACK / YELLOW | | dr kick or behind fbox |
PARKING LIGHTS - | none | | |
DOOR TRIGGER | yellow | - | front of fusebox *4 |
HEADLIGHTS | violet/white | + | light switch |
WIPERS | dk. GREEN/ YELLOW | + | wiper switch |
LF WINDOW UP/DN | lt. blue - white | A | driver door switch |
RF WINDOW UP/DN | brn/wht - ppl/white | A | driver kick panel |
LR WINDOW UP/DN | blue/wht - RED / green | A | driver kick panel |
RR WINDOW UP/DN | gray - GREEN / WHITE | A | driver kick panel |
TRUNK/HATCH PIN | tan/black | - | driver kick panel |
HOOD PIN | none | | |
TRUNK/HATCH RELEASE | BLACK/ white | + | driver kick panel |
FACTORY ALARM ARM | GREEN/ orange *6 | + | kick or BCM |
FACTORY ALARM DISARM | same wire | | |
HORN TRIGGER | BLACK/ red | - | steering column |
BRAKE WIRE | WHITE/ tan | + | brake pedal switch |
LOCK MOTOR | ORANGE / black | + | driver kick panel |
UNLOCK MOTOR | blue/white | + | driver kick panel |
DISARM DEFEAT | pink/black | + | rear of fuse box under dash |
DISARM NO UNLOCK | none | | |
DOME SUPERVISION | none | | |
SPEED SENSE | none | | |
SUN ROOF OPEN/CLOSE | none | | |
SUN ROOF LIMIT | none | | |
LF SPEAKER | none | non | none |
RF SPEAKER | none | non | none |
LR SPEAKER | none | non | none |
RR SPEAKER | none | non | none |
RADIO 12V | none | non | none |
RADIO GROUND | none | non | none |
RADIO SWITCH | none | non | none |
RADIO ILLUMINATE | none | non | none |
POWER ANTENNA | none | non | none |
Notes:NOTE: All models with a gray ignition key require the use of DEI part number 555C or 555U when adding a remote start. *1 When doing remote start red should not be used for main power. Use pink/black. *2 If BLACK/ gray on V6 causes starter to drag, use any one of the fuel injection wires at injectors at front of engine. The injector wire will be the one that IS NOT dk. GREEN/ orange. *3 Use positive (+) trigger thru a 620 ohm resistor to lock, and a positive (+) trigger thru a 2.7K ohm resistor to unlock. Must use relays. *4 In a three pin connector near the door jam. *5 Keyless entry module located in top dash area. *6 Lt. GREEN/ orange from driver's door or dk. GREEN/ orange from passenger or catch either at BCM located behind right side dash. Use a positive (+) trigger thru a 940 ohm resistor to arm, and a positive (+) trigger thru a 470 ohm resistor to disarm. Must use relays. |
mito57
Member -
Posted: May 15, 2004 at 7:10 PM / IP Logged
Thanks. Just what I needed.
Thursday, May 2, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
