wiring diagram
chicomax75235
Copper - Posts: 70
Posted: May 22, 2004 at 4:25 PM / IP Logged
need a detale wiring diagram on a 2003 silverado?
Jose Chapa
jfk51502003
Copper - Posts: 221
Posted: May 22, 2004 at 5:02 PM / IP Logged
you need only one post...
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / FULL SIZE PICKUP / 2003 / Remote Start
[PRINT THIS PAGE]
12volts red (x2)  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition white  +  ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
Keysense lt. green  -  ignition harness
Power Lock use Directed module 456G
Notes: If Directed module 456G is not available, refer to DirectFax document 1601. On base model trucks the lock wire is lt. blue (-), pin B5, and unlock wire is white (-), pin B10. They are in the lt. blue plug at the BCM.
Power Unlock see power lock
Lock Motor gray    driver door module in door
Unlock Motor tan    driver door module in door
Parking Lights+ do not use
Parking Lights- gray/black  -  brn plug, pin B2 @ BCM
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white  -  steering column, 5 pin plug
Turn Signal(L) green  +  steering column, 5 pin plug
Turn Signal(R) lt. green  +  steering column, 5 pin plug
Reverse Light lt. green  +  blk plug, pin F @ BCM
Door Trigger gry/blk (L), blk/wht (R)  -  each door module in door
Notes: On base model trucks the door trigger wires are in the lt. blue plug at the BCM, pins B4 and A5. On 4dr trucks the LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2. They are in the purple plug at the BCM. Use all wires and diode isolate.
Dome Supervision gray/black  +  BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm lt. green  -  driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white  ac  instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to start blue  -  instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The wait to start wire is in the green plug, pin 36.
Brake Wire white  +  brake pedal switch
Parking Brake lt. blue  -  lt. blu plug, pin A7 @ BCM
Horn Trigger BLACK / YELLOW to black  -  steering column
Memory Seat 1 red  +  driver door module in door
Memory Seat 2 pink  +  driver door module in door
Memory Seat 3 N/A  +
wiring diagram - Last Post -- posted image.
Immobilizer Bypass Module:Required: YesType: Passlock 2Part #: 555L or 555T
Notes: The Passlock 2 wire colors are yellow, black, and RED / white (not used).
jaxon23
Member - Posts: 25
Posted: May 22, 2004 at 5:15 PM / IP Logged
can you get a print out like that for a remote start on a 1998 Mitsubishi Eclipse Spyder GS. that is very informative
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
