head unit problems
leevander
Member - Posts: 20
Posted: May 26, 2004 at 9:25 PM / IP Logged
sometimes when i get finished listening to my cds in my head unit and try to eject the cd it wont come out and i have to take the head unit out and tilt it up.  when i do this i hear a clicking noise and the cd starts to play again and then i can eject the cd.  what could be the problem?
bj hargrove
Moderator - Posts: 12,488
Posted: May 27, 2004 at 9:09 AM / IP Logged
The eject tray is out of alighment. Had this happen to a new Pioneer deck that we sold and we just sent it back to get repaired.
DYohn
Moderator - Posts: 10,741
Posted: May 27, 2004 at 9:48 AM / IP Logged
If you're using CD-R's it might also be that the mechanism is having trouble dealing with it because CD-R's are thicker than standard CDs.  What's the head?
leevander
Member - Posts: 20
Posted: May 27, 2004 at 10:06 AM / IP Logged
I have a Pyle PLCD24.
bj hargrove
BangBang
Silver - Posts: 287
Posted: May 27, 2004 at 1:26 PM / IP Logged
Thos are all possibilities.  Check the motor. Mostly likely its weak. and out of line.
DYohn
Posted: May 27, 2004 at 1:37 PM / IP Logged
Pyle equipment is not very well built.  In fact, I'd call it "disposable."  That particular deck is not designed for CD-R's (even though it will play them) so it may simply be the mecahnism is hanging if you have run CD-Rs through it.   I suspect however that  it has simply failed and it is time to pull it and toss it.  It will cost your three times what it is worth to even get it looked at by a service center.  Replace it, and if you can I highly recomend you purchase a better quality head unit.
BangBang
Silver - Posts: 287
Posted: May 27, 2004 at 1:43 PM / IP Logged
If you plan on selling it or throwing it away Let me Know . I will be interested!
leevander
Member - Posts: 20
Posted: May 27, 2004 at 3:25 PM / IP Logged
i've only had it for about 3 weeks.  Does anybody think i should get a new head unit?
bj hargrove
Sweekster
Silver - Posts: 481
Posted: May 27, 2004 at 4:43 PM / IP Logged
I would. But it depends on your financials. I would save up for something better. Try to avoid brands like Pyle, pyramid, boss, lanzar, legacy, xplosion, power acoustik, volfenhag, hugfen...i could go on all day. If you're looking for just a cd player then you may want to look into the lower model head units made by companies like pioneer, jvc, panasonic...even a dual might be better that what you have.
Duane...
If you think you're confused, imagine how you feel.   head unit problems -- posted image.
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
