2001 Monte Carlo, alarm/remote start
osokrayzay
Copper - Posts: 54
Posted: May 21, 2004 at 3:13 PM / IP Logged
Please , Thx
Takes a long time to find it by swithcing the numbers on the directtech.coms links. :)
boomer_106
Silver - Posts: 710
Posted: May 24, 2004 at 8:37 PM / IP Logged
Chevrolet
Monte Carlo
2000-2003
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
Yellow (+)
Ignition switch harness**
Ignition #1:
Pink (+)
Ignition #2:
Dk.Green (+)
Ignition #3:
N/A
Accessory:
Orange (+)
Brake Light:
White (+)
Brake pedal switch
Tach Signal:
White (AC)
Ignition coil
Parking Lights:
White (-)
Pink # pin plug at BCM***
Headlights:
OEM Alarm Disarm:
Lt.Green (-)
Gray # pin plug @ BCM***
OEM Alarm Arm:
Diesel Glow Plug:
N/A
Clutch Bypass Wire:
Notes:
* This Vehicle Is Equipped With GM's Passlock II Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. **The ignition harness is located on the far right side of the steering column, behind the ignition switch. ***The BCM (Body Control Module) is located above the brake pedal. Is is a plastic box with three plugs that face the firewall.
Chevrolet
Monte Carlo
2000-2003
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
Red (+)
Starter Kill:
Yellow (+)
Ignition +12 Volts:
Pink (+)
Dome Lights/Superv:
Green
OEM Horn:
Black (-)
Steering column harness
Power Lock:
ORANGE / Black (-)
Gray # pin plug at BCM****
Power Unlock:
ORANGE / Black (-)
Trunk Release:
Black (-)
Release switch
Alarm Input Wire:
Green
Notes:
**** Single Wire Door Lock System. A Negative (-) Ground Pulse Through A 470 Ohm Resistor Will Lock The Doors. A Negative (-) Ground Pulse Will Unlock The Doors.
osokrayzay
Copper - Posts: 54
Posted: May 28, 2004 at 2:27 AM / IP Logged
The mc comes with a ACCESSORY /HEATER BLOWER 1=ornage and ACCESSORY /HEATER BLOWER 2=brown. The wiring info from here http://bulldogsecurity.com/New%20Wires/New%20Wires/Wires/monte00-03.htm says - This wire must be powered as an accessory wire. If powered as a 2nd ignition the car will not crank. I am using a 791xv. Do i connect both orange and brown to the accesory ouput of the alarm=orange?
TIA!
osokrayzay
Copper - Posts: 54
Posted: May 28, 2004 at 3:03 AM / IP Logged
I'm guessing I just leave that brown wire alone?
draasch
Gold - Posts: 2,172
Posted: May 28, 2004 at 9:08 AM / IP Logged
you will need to use a relay so you dont overload anything...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
osokrayzay
Copper - Posts: 54
Posted: May 28, 2004 at 1:57 PM / IP Logged
thx.
Im always having a hard time getting the tach wires.
zargon
Copper - Posts: 186
Posted: May 28, 2004 at 5:07 PM / IP Logged
on this car do not engerize the brown wire. it will work fine at first and as time goes by you will notice the car will not crank as soon as you turn the key but has a delay, and things will go down hill from there.you dont need the brown wire, trust me.
zargon ruler of estranorth
osokrayzay
Copper - Posts: 54
Posted: May 28, 2004 at 5:19 PM / IP Logged
thx
Do you know if the tach wire is the white wire located in a 4 wire harness next to the spark plugs?
TIA
osokrayzay
Copper - Posts: 54
Posted: May 28, 2004 at 6:26 PM / IP Logged
nvm i checked with a mm and it showed 1 volt. plus it had that little black thingy next to it so i tried it and it works.
osokrayzay
Copper - Posts: 54
Posted: May 28, 2004 at 9:52 PM / IP Logged
sigh
The doors doesnt trigger when opened. I took the trigger from the underdash light. The light remains on. When i arm the door says its open on the viper 791vx 2 -way
any help
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
