2001 Nissan Pathfinder
Krazzyborri
Copper - Posts: 56
Posted: June 23, 2004 at 4:51 PM / IP Logged
Does anyone have the Schematics for a 2001 Nissan Pathfinder???
Thanx
draasch
Gold - Posts: 2,172
Posted: June 23, 2004 at 11:39 PM / IP Logged
Make:   Nissan
Model: Pathfinder
Year:    2001
This Database Was Last Updated On:    4/7/2004
Index #: 5494
Alarm
Constant 12 volts WHITE/ GREEN IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light RED / BLACK (-) DRIVER KICK PANEL *
Trunk Pin Switch RED / BLACK (-) SAME CIRCUIT AS ABOVE
Parking Lamp PINK/BLUE (+) 16 PIN WHT CONN AT REAR OF FUSE BLOCK
Power Lock L GREEN/ RED 16 PIN WHT CONNECTOR ** #201
Power Unlock BROWN IN DRIVER KICK PANEL
* With Oem Alarm Only: RED / BLACK (-) Changes To RED / BLUE (-) In Driver Kick Panel. ** Door Locks Also Located At "Smart Entry Control Timer" Behind Left Side Of Driver Dash On Right Side Of Fuse Block. #201- See Negative Pulse Door Lock Diagram.
Accessories
Window Up D\ BLU/RED P\ BLU/RED D\ RED / BLK P\ WHT/BLK @ MAIN #211
Window Down F/ BLU/BLK F/ BLU/BLK R/ GRN/WHT R/ BLK/WHT SWITCH **
Ign Key Warn WHITE/ RED (+) IGNITION SWITCH HARNESS
Trunk Release N/A
OEM Horn L GREEN/ BLACK (-) STEERING COLUMN HARNESS
Headlights VIO/WHT (DR) & VIO/WHT (PS) (-) HEADLAMP BATTERY SVR CNTRL *
OEM Alarm Arm YELLOW (-) AT "SMART ENTRY CONTROL UNIT"
OEM Alarm Disarm L GREEN (-) LOCATED BEHIND LEFT SIDE OF DR. DASH
#211- See Reversal Rest At Ground Power Window Circuit Diagram. * W/ Auto Lamp - Headlight Battery Saver Control Unit Located In Driver Kick Panel. W/out Auto Lamp - VIOLEY (DR) & GRY/BLU (PS) (-) At Headlight Battery SaverControl Unit. ** Driver Door And Rear Doors Can Be Accessed At Main Switch. Passenger Door Must Be Accessed At Passenger Switch.
Remote Start
Tach Signal WHITE/ GREEN AT ENGINE CONTROL MODULE * #239
Ignition #2 RED / YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory WHITE/ BLUE IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN/ YELLOW (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light YELLOW (+) 20 PIN WHT CONN. IN PASS. KICK PANEL
Rear Window Defrost ORANGE (-) AT REAR WINDOW DEFOGGER SWITCH
* Engine Control Module Located Behind Driver Dash Right Of Steering Column. Note From Installer: Tach Listed Did Not Work, Proper Connection Is A BLACK/ WHITE At Tacho Module Located Left Of Steering Column In The Top Plug. #239 See Immobilizer Bypass Diagram. Cold Start Wire - RED / BLACK In Ignition Switch
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
