2000 Ranger Alarm unlock sense wire?
MikeD916
Member - Posts: 8
Posted: July 10, 2004 at 1:04 AM / IP Logged
Im installing a Ford OEM System 4 alarm on my Ranger and I can't find the unlock sense wire. The color chart (for 2000 Ranger) says its a pink/orange wire in the left kick panel but I still can't find it. Without this wire hookup the alarm system dosn't work properly. At this point without the wire any joe blow can press my unlock switch which will disable my alarm. Any help would be appreciated. Thanks.
Mike
Ford 2000 Ranger 4x4 3.0 v6
2000 Ford Ranger 3.0 V6 4x4 Extendedcab
jfk51502003
Copper - Posts: 221
Posted: July 10, 2004 at 1:14 PM / IP Logged
Power Lock pink / YELLOW   -  either door harness or   2000 Ranger Alarm unlock sense wire? -- posted image.
Power Unlock pink/green   -  either door harness or   2000 Ranger Alarm unlock sense wire? -- posted image.
Lock Motor pink/black    drivers door harness
Unlock Motor RED / orange    drivers door harness
Factory Alarm Arm arms w/ lock
Factory Alarm Disarm dk. GREEN/ purple   -  drivers kick panel
Disarm No Unlock
Horn Trigger yellow/lt. green   -  steering column   2000 Ranger Alarm unlock sense wire? -- posted image.
avxtech
Member - Posts: 35
Posted: July 10, 2004 at 3:40 PM / IP Logged
That wire may also be pink/green in d.kick
MikeD916
Member - Posts: 8
Posted: July 11, 2004 at 1:34 AM / IP Logged
Thanks for the replies. I just found it. Its an all unlock relay wire that is Pink/Orange that runs from the right door to the drivers side unlock relay. Now I can finally finish my install.
