1986 Vette
C4Me
Member - Posts: 7
Posted: July 13, 2004 at 12:16 PM / IP Logged
I am looking for a simple solution for my 86' vette to add keyless entry and still use my VATS system.  Any hints?
Thanks, C4Me
kgerry
Platinum - Posts: 3,455
Posted: July 13, 2004 at 1:57 PM / IP Logged
does it have power locks now?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Javelin3o4
Copper - Posts: 239
Posted: July 14, 2004 at 12:50 AM / IP Logged
The VATS system just stops the car from being started until the correct resistance is seen from the key, it has nothing to do with your door locks. if you are just wanting keyless entry by a keyless entry system and add door lock actuators if it doesnt have power locks. When you install remote start and have to do the "VATS bypass" it doesnt totally remove the feature of the VATS system just allows the car to be remote started by sensing the resistance value of the resistor you had to install. You still need the key with the chip in it for the car to start/run
C4Me
Member - Posts: 7
Posted: July 14, 2004 at 6:55 AM / IP Logged
Kevin,
 Yes the car has power door locks.  I am interested in something as described in Javein3o4's post.  At one time, one of the aftermarker sellers of vette parts was hauking a system that was "plug and play" but they have dicontinued.  I e-mailed the company but have had no response.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
