clifford rsx 3.5 remote start problem
redcivicgsr
Posted: July 22, 2004 at 7:52 PM / IP Logged
i have everything installed...the ignition will come on but the starter won't come on.  i can hear the fuel pump priming and everything but the starter isn't even trying.  any thoughts?
Javelin3o4
Copper - Posts: 239
Posted: July 22, 2004 at 9:18 PM / IP Logged
did you hook your starter kill relay up right? what about a bypass module for remote start?
what year and model car?
jc18750
Copper - Posts: 113
Posted: July 25, 2004 at 5:37 AM / IP Logged
do you have a transponder chip in your key? try remote start with the key in the ignition (off position). if it works, you need a bypass.
draasch
Gold - Posts: 2,172
Posted: July 25, 2004 at 9:02 AM / IP Logged
what is the year make and model of car????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
