Figuring sub volume
swede
Copper - Posts: 125
Posted: August 01, 2004 at 3:48 PM / IP Logged
I know there's a calculator for this as I've been using it alot lately - heh heh...maybe I missed the rules, but when a sub has a volume rating, does that include the sub itself or does that have to be added as well?
Sounds basic I know but I would expect a manufacturuer to include/subtrat the volume of the sub itself when they give the requirements.
2002sportside
Member - Posts: 13
Posted: August 01, 2004 at 4:47 PM / IP Logged
Most manufacturers don't include the sub's volume (some do though).  You need to make a box with this in mind.  Taken directly from RF's manual... "The speaker itself also reduces the internal volume.  The amount of air displaced by each model is listed on the specification sheet and should also be subtracted from the gross volume calculation."
But, a sub doesn't displace a ton of room so it shouldn't mess up your box calculations too much.
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: August 01, 2004 at 5:04 PM / IP Logged
I agree.  I hightly doubt you would be able to hear a difference even with the large supersubs.
Steven Kephart
Adire Audio
swede
Copper - Posts: 125
Posted: August 01, 2004 at 8:28 PM / IP Logged
Thanks very much. I've got more ideas than experience in this so this forum - and all your inputs - have been a gift to find.
My box is square then tapers at the bottom for its location/application. The sub's volume - a Boston Pro 12" - requirement is 1.0....my box figures to be .99572, so I'll call it goodFiguring sub volume - Last Post -- posted image.
Thanks again.
Subtlety is EVERYTHING.
stevdart
Platinum - Posts: 5,816
Posted: August 01, 2004 at 9:58 PM / IP Logged
Can't get much closer than that   :)
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
