Looking for new Pair of subs
Sebastian018
Silver - Posts: 364
Posted: August 11, 2004 at 1:16 AM / IP Logged
Hi, this is my setup Pioneer Premier AVH-P6500DVD as a head unit, DEQ-9200 graphic equalizer and my amps which are a soundstream for the mid an highs, and a Memphis Memphis 16-MC1000D for my subs (which i was currently using at 1 ohm) I both two Of the Kove subs (the ones from partexpress.com) and I was using it in a ported box. They were amazing at 1 ohms. The only problem is that the Box was TOOOO Big, That i didnt have any space at all in the trunk, so i decide to sell ( it took me 3 month to finally decide to sell it because I really like them but because of the size I do not want to keep them) . now im looking for two 12" that Recommended a small vented box. (the koves were in a 2.75 cu. ft. vented box).
some of the sub that i thinkin and i want you opinion or which could be a good option, they have to be Dual 4 ohms so i can wire then at 1 ohm.
Rockford Fosgate T212D4
Alpine Type-X SWX-1242D
MTX Thunder7500 T7512-04
SOUNDSTREAM T2-12
Jl audio 12W6v2 ( 400 rms each)
davids2004
Member - Posts: 26
Posted: August 11, 2004 at 3:39 AM / IP Logged
Are you looking for SQ or SPL.
Sebastian018
Silver - Posts: 364
Posted: August 11, 2004 at 11:07 AM / IP Logged
More SPl than SQ. that's why itsgoing in to a Vented box...
pimpincavy
Silver - Posts: 880
Posted: August 11, 2004 at 9:22 PM / IP Logged
I would go with either the alpine or the mtx, but thats just my opinion.
customsuburb
Gold - Posts: 1,813
Posted: August 11, 2004 at 9:36 PM / IP Logged
I'd probobly go with the RF sub. Stick it in a ported box and you should be happy. The T1s arn't that bad either and they would require less power, unless you have an amp already.
envoy62
Member - Posts: 6
Posted: August 11, 2004 at 10:52 PM / IP Logged
If spl is objective the MTX are a good choice, but the box for  2 12's i would not consider small. I think the box for 2 of these will be only a little bit smaller then your previuos set up. You can use winISD (free program) to calculate box sizes and tune the box to your likeing.
there is a solution to every problem
Sebastian018
Silver - Posts: 364
Posted: August 11, 2004 at 10:56 PM / IP Logged
ANd what do you guys think about Rockford the T1 model. DOes anybosy know how they sound>>.
vdubmk4
Copper - Posts: 175
Posted: August 11, 2004 at 11:29 PM / IP Logged
Definitely I would have to go with the MTX's although the Alpines i would have to say are dernn good. Personally i have two thunder 8000's and they are magnificent.
Fortune: You will continue to take chances, and be glad you did.
MBZ oe
Silver - Posts: 385
Posted: August 15, 2004 at 5:37 PM / IP Logged
Top-End Diamond Audios!!!!!!!!!!!!!!!!!!!!!!!
boom, boom, boom boom....
Friday, May 17, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
