1991 Pontiac Sunbird Ignition Switch Wiring Connector
sandytoth
Posted: September 09, 2004 at 4:45 PM / IP Logged
I have a need for the connector diagram for the wiring on a 1991 Pontiac Sunbird Ignition switch Wire harness Connectors.  Can Anyone Provide?
Thanks for your help.
Sandy
Teken
Gold - Posts: 1,492
Posted: September 15, 2004 at 5:01 PM / IP Logged
Pontiac
Sunbird
1989-1994
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   YELLOW
IGNITION SWITCH HARNESS
Ignition #1:
   PINK
Ignition #2:
   ORANGE
Ignition #3:
   N/A
Accessory:
   BROWN
Brake Light:
   WHITE/ BLUE OR LIGHT
BLUE (+) SWITCH ON BRAKE PEDAL BRACK.
Tach Signal:
   WHITE
AT DISTRIBUTOR
Parking Lights:
   BROWN
(+) AT HEADLIGHT SWITCH
Headlights:
   YELLOW (+)
HEADLIGHT SWITCH OR BEAM SELECT SW.
OEM Alarm Disarm:
   N/A
OEM Alarm Arm:
   N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
Pontiac
Sunbird
1989-1994
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   RED AND RED
IGNITION SWITCH HARNESS (ONE CIRCUIT)
Starter Kill:
   YELLOW
Ignition +12 Volts:
   PINK
Dome Lights/Superv:
   WHITE (-)
COURTESY LIGHT OR CONVENIENCE CENTER
OEM Horn:
   BLACK (-)
STEERING COLUMN HARNESS OR AT RELAY
Power Lock:
   LIGHT BLUE
DRIVER'S KICK PANEL OR AT RELAYS **
Power Unlock:
   BLACK
Trunk Release:
   BLACK
(+) AT RELEASE SWITCH
Alarm Input Wire:
   WHITE (-)
Notes:
** See Note #202 - Positive Pulse Door Lock Diagram.
Teken
Gold - Posts: 1,492
Posted: September 15, 2004 at 5:03 PM / IP Logged
SUNBIRD 1990-1994
WIRE COLORS LOCATION
12 VOLTS CONSTANT RED
IGNITION 1    PINK (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER ORANGE (+) IGNITION SWITCH HARNESS
STARTER YELLOW (+) IGNITION SWITCH HARNESS
PARKING LIGHTS (+) BROWN at HEADLIGHT SWITCH
DOME LIGHT WHITE (-) at UNDER DASH LIGHT
POWER DOOR LOCK LIGHT BLUE in DRIVERS KICK PANEL (TYPE "A")
POWER DOOR UNLOCK BLACK in DRIVERS KICK PANEL (TYPE "A")
TRUNK RELEASE BROWN (+) at RELEASE SWITCH
TACH SENSOR WHITE or PURPLE / WHITE at ECM located behind and above GLOVE BOX on passenger side of vehicle.
BRAKE
WHITE (+) at the BRAKE SWITCH
HORN
BLACK (-)
at STEERING COLUMN HARNESS
Teken
Gold - Posts: 1,492
Posted: September 15, 2004 at 5:04 PM / IP Logged
12V red + ignition harness
STARTER yellow + ignition harness
IGNITION pink + ignition harness
ACCESSORY orange + ignition harness
SECOND ACCESSORY none
TACHOMETER white or pur/wht ECM *4
POWER LOCK lt. blue + drivers kick panel
POWER UNLOCK black + drivers kick panel
PARKING LIGHTS + brown headlight switch *1
PARKING LIGHTS - none
DOOR TRIGGER *2 - *2
HEADLIGHTS yellow or tan + headlight switch
WIPERS purple + wiper motor
LF WINDOW UP/DN blue - brown A center console switch
RF WINDOW UP/DN blu/wht - tan A center console switch
LR WINDOW UP/DN green - purple A center console switch
RR WINDOW UP/DN lt. green - pur/wht A center console switch
TRUNK/HATCH PIN BLACK/ orange *3 - low in the drivers kick
HOOD PIN none
TRUNK/HATCH RELEASE brown + release switch
FACTORY ALARM ARM none
FACTORY ALARM DISARM none
HORN TRIGGER black - steering column
BRAKE WIRE white + brake light switch
LOCK MOTOR none
UNLOCK MOTOR none
DISARM DEFEAT none
DISARM NO UNLOCK none
DOME SUPERVISION white - underdash light
SPEED SENSE green 4 ECM *4
SUN ROOF OPEN/CLOSE none
SUN ROOF LIMIT none
LF SPEAKER none non none
RF SPEAKER none non none
LR SPEAKER none non none
RR SPEAKER none non none
RADIO 12V none non none
RADIO GROUND none non none
RADIO SWITCH none non none
RADIO ILLUMINATE none non none
POWER ANTENNA none non none
Notes: *1 Also found low in the drivers kick panel. *2 Use lt. GREEN/ black for the drivers door and lt. blue for the passengers front door. For the 2 door models, use both wires and diode isolate each. For the 4 door models, see directfax document #1075. *3 Only available on models with a ajar indicator in the instrument cluster. *4 The ECM is behind and above glovebox on passengers side.
sandytoth
Posted: September 16, 2004 at 2:15 PM / IP Logged
Teken,
Thanks for the information.  Thanks to all who checked out my question, whether you could reply or not.
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
