voice coil impedance
thepyrofish
Member - Posts: 36
Posted: September 26, 2004 at 5:07 PM / IP Logged
{TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" UNABLE="on"}{TR height="100%" UNABLE="on" width="100%"}{TD id=HB_Focus_Element vAlign=top width="100%" background=""0 UNABLE="off"}{p}I recently installed a sub in my car that I was told was a dual 2-Ohm speaker, but when it didn't meet up to expectations I decided to check the resistance with a multimeter to be sure.  i got 5.1 ohms on one coil and 5.2 or 3 on the other.  I know the impedance that is measured on a DMM is not exactly the rated one, but what would this speaker be if they measure that high, I was thinking dual 4 but I was expecting a reading of closer to 4 for that, is my sub damaged?{/p}{p}It is a soundstream DV-12 , by the way,{/p}{p}any ideas?{/p}{/TD}{/TR}{TR UNABLE="on" hb_tag="1"}{TD style="FONT-SIZE: 1pt" height=1 UNABLE="on"}{DIV id=hotbar_promo}{/DIV}{/TD}{/TR}{/TABLE}
stevdart
Platinum - Posts: 5,816
Posted: September 26, 2004 at 7:01 PM / IP Logged
Yes, a dual 4 ohm sub.  You're possibility of wiring would be parallel for a 2 ohm load, if you have a mono amp.  I would guess, though, that you are bridging a stereo amp?  And ended up with a 8 ohm load with coils in series?
thepyrofish
Member - Posts: 36
Posted: September 26, 2004 at 9:03 PM / IP Logged
{TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" UNABLE="on"}{TR height="100%" UNABLE="on" width="100%"}{TD id=HB_Focus_Element vAlign=top width="100%" background=""0 UNABLE="off"}{p}exactly, i thought it was a two ohm and wired it exacty how you said, so it ended up being 8{/p}{p}thanks for your help{/p}{/TD}{/TR}{TR UNABLE="on" hb_tag="1"}{TD style="FONT-SIZE: 1pt" height=1 UNABLE="on"}{DIV id=hotbar_promo}{/DIV}{/TD}{/TR}{/TABLE}
DYohn
Moderator - Posts: 10,741
Posted: September 27, 2004 at 8:18 AM / IP Logged
thepyrofish, please type your posts directly in the web window, don't cut and paste from another application.  This will help avoid the confusing result seen above with all your HTML formatting code visible.
thepyrofish
Member - Posts: 36
Posted: September 27, 2004 at 8:54 AM / IP Logged
sorry about that, I was typing directly into the browser but I was at a friends house and his computer ain't quite right.
haemphyst
Platinum - Posts: 5,054
Posted: September 27, 2004 at 12:48 PM / IP Logged
ummm, I think that a 5.2 ohm (DC) driver would be closer to a real world 8 ohm impedance... a DCR will NEVER be higher than a reactive impedance. If you wired those voice coils in series, you would have a 16 ohm load presented to the amp. You need to parallel the voice coils for a 4 ohm load, then either run it that way to a mono amp, or bridge a stereo amp to get two ohms per channel, a (usually) safe load for most amplifiers of today.
stevdart
Posted: September 27, 2004 at 8:09 PM / IP Logged
FYI, one of the posts was deleted.  In it thepyrofish said that he checked internal resistance of the DMM by touching probes together and got a 1.5 (if I remember exactly) reading, so he deducted the 1.5 from the reading of 5.2 and arrived at 3.7 ohms, with which I have agreed seemed usual for a 4 ohm driver.
