97 GrandAm Wiring
CementBrain
Copper - Posts: 61
Posted: September 27, 2004 at 12:22 PM / IP Logged
I was checking out the wiring diagrams on this site and at designtech. Wiring diagrams do not match.
DESINGTECH                      THIS SITE
Start:        Yellow -----------Yellow
Ignition #1: Pink -------------Pink
Ignition #2: White ------------White
Ignition #3: N/A --------------Brown
ACC:          Orange -----------Orange
Ect.
When I looked at my car, it has the Brown one.
Does that mean that I must install another relay for the Brown one too?? Remote starter is installed but I have a couple of bugs with it. I have the AstroStart 803, which has a built in relay for the second ingnition wire but not a third.
CementBrain
raydawg357
Silver - Posts: 769
Posted: September 27, 2004 at 12:28 PM / IP Logged
mo12v
Posted: September 27, 2004 at 12:33 PM / IP Logged
Constant 12 voltsRED & REDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightL GRN/BLK & L BLUE (-)AT CONVENIENCE CENTER MODULE *
Trunk Pin SwitchORANGE / BLACK (-)AT LIGHT IN TRUNK
Parking LampBROWN (+)AT LIGHT SWITCH OR DRIVER KICK PANEL
Power LockL BLUEEITHER KICK
Power UnlockWHITEPANEL
* Convenience Center Module Located Behind Driver Dash To Left Of Steering Column. L GREEN/ BLACK (-) Covers Driver Door, L BLUE (-) Covers All Other Doors. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires.  Positive Pulse Door Lock
Accessories
Window UpD\ D BLUE P\ L BLUE D\ D GREEN P\ L GREEN @ MAIN SWITCH
Window DownF/ BROWN F/ TAN R/ PURPLE R/ PURPLE
Ign Key WarnL GREEN (-)STEERING COLUMN HARNESS
Trunk ReleaseBLACK (+)AT OEM KEYLESS MODULE IN TRUNK *
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsYELLOW (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/ANO OEM ALARM PRESENT
OEM Alarm DisarmN/AIN SCHEMATICS
 Reversal Rest At Ground Power Window Circuit Diagram. * BLACK (+) Wire For Trunk Release Is With OEM Keyless Only. Without OEM Keyless Trunk Release Is Cable Operated.  Positive Pulse Trunk Release
Remote Start
Tach SignalWHITEAT POWERTRAIN CONTROL MODULE *
Ignition #2ORANGEIGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3WHITEIGNITION SWITCH HARNESS **
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyORANGE / BLACK (-)AT CONVENIENCE CENTER MODULE ***
Brake LightL BLUE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)PASSENGER KICK PANEL
Rear Window DefrostL BLUE (+)AT REAR WINDOW DEFOGGER SWITCH ****
* 3.1L Engine Tach Wire Is WHITE Or PURPLE / WHITE At Powertrain Control Module. Powertrain Control Module On Both Engines Located Behind Pass. Dash ** WHITE Wire Powers Instrument Cluster And Transmission Control Module. *** Convenience Center Module Located Behind Dr, Dash To Left Of Steer. Col. **** L BLUE (+) Wire Also Located At Convenience Center Module.  G.M. Passlock
MO
CementBrain
Copper - Posts: 61
Posted: September 27, 2004 at 12:35 PM / IP Logged
It, too only shows Pink and White Ingnition wires, I seem to have 3. PINK, WHITE and BROWN
CementBrain
mo12v
Posted: September 27, 2004 at 12:44 PM / IP Logged
Ignition #2ORANGE
Ignition #3WHITE
AccessoryBROWN
MO
CementBrain
Copper - Posts: 61
Posted: September 27, 2004 at 1:01 PM / IP Logged
mo12V -- Where did you get your info.
That's 2 for 2 now.
CementBrain
mo12v
Posted: September 27, 2004 at 1:07 PM / IP Logged
MICRO, OMEGA, DEI, & 20 years of stuff
There R many companies that offer wiring charts.  We always look at 2 or 3 charts to compare before we do any work.  But we ALWAYS check wires before hooking up.  Then we record the difference.
In an attempt to get as much information as possible to install shops A.S.A.P. U really have to double check.
MO
CementBrain
Copper - Posts: 61
Posted: September 27, 2004 at 1:20 PM / IP Logged
Thanks mo12V, that's why I here trying to make sure on the wiring. But there seems to be some discrepancy in wiring diagrams.
CementBrain
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
