Grounding multiple TV’s
thsonnen
Member - Posts: 27
Posted: September 28, 2004 at 7:42 AM / IP Logged
I am getting ready to install 4 tv's in my 2004 Duramax.
2 6.5" in the visor, and 2 7" in the headrest. My question is how do I go about grounding all 4 of these tv's. Should I ground them as short as possible separately, or should I ground them all at the same point? Also, what is the best kind of video jacks to use on these tv's?
dxav
Silver - Posts: 314
Posted: September 28, 2004 at 1:44 PM / IP Logged
What is a Duramax?
It is normal to ground components with the shortest length possible. In the case of a short, current will travel to the shortest path to ground. A fuse will help on each power wire, too.
Commonly, all your video signal wires will be run in one cable. This will have the 2-CH Audio, 1 Video, Power and Ground. You could splice all the grounds together and solder the connection to one larger wire (12-14 Ga would work well), then properly terminate to ground.
Video has optimal carry on a 75-Ohm cable. This is what you would need. Not sure about connection material, though.
DXAV
Ravendarat
Platinum - Posts: 2,806
Posted: September 28, 2004 at 2:36 PM / IP Logged
Duramax Diesel truck I am guessing
dxav
Silver - Posts: 314
Posted: September 28, 2004 at 6:14 PM / IP Logged
Excellent. I figured it was a truck.
DXAV
Wussy posts like this one (mine) shouldn't really count, huh?
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
