Grill Cloth or Fleece to wrap enclosures?
HottAccord
Silver - Posts: 247
Posted: October 01, 2004 at 12:01 AM / IP Logged
I know a lot of you prefer fleece, but has anyone used grill cloth or other fabrics/materials?  From what I see, grill cloth is way more stretchier than fleece and probably easier to work with.  I'm currently working on a stand alone enclosure with sort of a moon shaped base, and it's a real b-i-t-c-h trying to wrap it cause of the odd shape, so its been a hassle trying to remove wrinkles.  I have to constantly keep pulling the fleece off and resticking it.
Im a fiberglass whore!!
xtreamcc
Silver - Posts: 467
Posted: October 01, 2004 at 12:06 AM / IP Logged
See, the problem with grill cloth is that its so thin it literally will fall in on itself when streched to its max. Fleece on the other hand holds its dexterity when completely streched out and then resined. I know this isn't gona help u now but I make sure that when I design a box that it doesn't have 'hard-to-fleece' angles and bends and crap in it. The less work u have to do the better, the more open and and slightly graded curves u have the better, the less sharp cut offs and odd 360 degree curves u have the better. Box design is the key to a proper fleece job. Anyway, thats my ramble about grill cloth lol.
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
HottAccord
Silver - Posts: 247
Posted: October 01, 2004 at 8:16 AM / IP Logged
Thanks, I appreciate your input.  When I first started reading about glassing, I went onto the Alpine website and read about their demo cars.  They used grille cloth in all their applications.  I guess there are different grades/weights of grille cloth.
This is sort of the shape I was experimenting with, so from the pice here, I know it can be done somehow.
Grill Cloth or Fleece to wrap enclosures? -- posted image.
HottAccord
Silver - Posts: 247
Posted: October 01, 2004 at 8:18 AM / IP Logged
Well the pic did't show up, so here's the link:
https://i4.ebayimg.com/01/i/02/88/47/9f_1_b.JPG
ice4life8269
Copper - Posts: 112
Posted: October 04, 2004 at 8:10 AM / IP Logged
man that looks sweet! I'd tell you to get an extra set of hands to help you.... and use staples to attach the fleece to the base , if the base if MDF..... and as far as the hard-to-fleece angles go, you can make some support braces around the curves to give you more places to attach to fleece...... ALSO, if want to keep the bottom smooth, stretch the fleece as much as you can and staple it to the bottom AWAY from the edge, and when you resin it, only go to the bottom edge of your base, and don't use any resin on the bottom. then when you are done you can cut off all of the fleece from the bottom and take out the staples.... good luck!Grill Cloth or Fleece to wrap enclosures? -- posted image.
CarAudioHelp
Copper - Posts: 198
Posted: October 04, 2004 at 2:39 PM / IP Logged
A shape like that won't cause many problems until you get to the concave section. You'll need a fairly stretchy material but nothing too major looking at the picture. Polar fleece would probably work as long as you aligned the cloth the right way so the stretchy direction is running up and down on the concave area.
HottAccord
Silver - Posts: 247
Posted: October 04, 2004 at 7:57 PM / IP Logged
I definitely need to get my hands on a heavy duty staple gun for my next project.  I am aware of a few points mentioned here..I never resin under the enclosure past the edge, the 1st time I did it was a pain in the a$$ to trip the stiff fleece from the underside haha
Another thing that made it was easier to stretch the fleece over the wierd shape it to make sure your subwoofer ring is very stable.  I finally tried the 2 x 4 piece of wood and screwed the subwoofer ring onto the base.  This thing did not budge and it made stretching so much easier, no wrinkles at all..pics below
Anyway, I decided to cut off the edges on my base and work with a little more of a rounded shape, everything went well.  Check out  the pic below, more pics to come soon as I find more time to finish this stand alone piece.  I just finished adding bondo to the outside, so now it's time for some sanding...
Pic before fleece (ring mounted on 2 x 4 wood)
https://img.photobucket.com/albums/v398/hottaccord/FG2/IMAG0132.jpg
Wrapped in fleece - wrinkle free!! Grill Cloth or Fleece to wrap enclosures? -- posted image.
https://img.photobucket.com/albums/v398/hottaccord/FG2/IMAG0133.jpg
More pics to come soon.......
boxmaker85
Silver - Posts: 433
Posted: October 05, 2004 at 2:53 PM / IP Logged
I talked to a guy today said he went to nopi nats and saw a guy there w/ a 100% flece box.  No fg just resin and flece.  Made a sandwich w/ it.  Cloth like 2-3 layers of resin and then another cloth layer then another resin.  What do you guys think?  Will it hold if I put a 10" in it?  or shoud I just fg the thing?
CarAudioHelp
Copper - Posts: 198
Posted: October 05, 2004 at 6:07 PM / IP Logged
I've made many boxes without actual fiberglass. You just have to use the right cloth and make sure the enclosure won't see high power. The best stuff I've found is plush felt (FishFabric). It's about a quarter inch thick once you resin it. That's plenty thick for a lot of applications unless you have a large flat area. Curves = strength
boxmaker85
Silver - Posts: 433
Posted: October 05, 2004 at 7:04 PM / IP Logged
Plush felt huh?  Wal-mart?  Fabric Store?  So a sandwich will work fine for a single 10"?  Cool I'll go anc check out some stores today.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
