Difference btwn Autopage 750lcd + 850lcd?
sdsviet
Member - Posts: 12
Posted: October 05, 2004 at 2:50 AM / IP Logged
wat is really the big difference between the 750lcd and the 850lcd. is the range any better or is it just more features. i have a civic manual without power door locks but got actuators for it and will put that on soon.
sdsviet
Member - Posts: 12
Posted: October 05, 2004 at 5:31 PM / IP Logged
bump
sdsviet
Member - Posts: 12
Posted: October 06, 2004 at 2:09 PM / IP Logged
bump
jrilla
Gold - Posts: 1,498
Posted: October 06, 2004 at 3:55 PM / IP Logged
Well there is one thing that is the same about both: They are not designed for manual transmission vehicles? If you dont never install the remote start features, then you can use it as just an alarm, but otherwise you should get a unit designed for manual transmission vehicles.
Otherwise: I cant say about the range, but I have a 750 and the range is fine. There are no auxiliary outputs on the unit besides the trunk output. The 850 has a bunch of aux. outputs. Otherwise there is not much difference as far as I know.
J Rilla
Owner/Installer
sdsviet
Member - Posts: 12
Posted: October 07, 2004 at 2:09 AM / IP Logged
so can the trunk output be used for something else? and if i personal put in the neutral safety myself will the remote start work with it then? yea i decided to get the 750 cuz my cousin is letting me have it for cheap.
Charles_R_H
Copper - Posts: 122
Posted: November 23, 2004 at 10:11 PM / IP Logged
the 750 transmitter is an AM frequency, while the 850 is  a FM frequency
1000 feet AM 2000 feet FM
AM won't work if you are in a metal building and try to use the transmitter
electronics run off of smoke, when you let the smoke out they stop working
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
