Clifford Matrix RS 3.5 door locks
jorgefdz
Copper - Posts: 99
Posted: October 08, 2004 at 12:01 AM / IP Logged
how do I connect this door locks to my tahoe 1998?
thank you.
Does this alarm have "ground when remote star" wire?
thank you.
j.f.l.l.
hagmanti
Silver - Posts: 304
Posted: October 09, 2004 at 2:03 PM / IP Logged
From 1998 Chevrolet Tahoe Alarm Information, the doors are positive trigger. Door Lock is Light Blue and located "Above Accelerator Pedal at Factory Relays" - run the blue wire from the door lock harness (3-pin connector) to this; Door Unlock is White - run the green wire to this.
Before running any wires, put a DMM from these wires to 12V (red -> 12V, black to test wire). DMM should read 12V most of the time, dropping to 0 when you press the lock (or unlock) button. If you don't see this behavior on the wires you're hooking up to, don't hook things up to them!
Blue (-) status output on the relay pack is ground when remote start active. (Look at the last page of the manual)
Hope this helps,
Me
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
